Any tips on getting that clamp off ? The front one was easy the down pipe gave a little fight but that one looks like a pain to get at I haven't realy took a good look at it yet though
2100* high temp ceramic paint from Napa...
soak the clamp with BP blast or WD-40 starting right now and keep it wet till your ready to pull it..use a screw driver to pry it off..here is a small clip of Marty putting the clamp together then putting it on the turbo..it will give an idea how the clamp works Turbo :: Turbo video by MazdaMartinb4k - Photobucket
The only thing I have to add, is that the clamp faces the other way. In the video, it is installed the opposite way. The T bolt points toward the driver's side to be able to access the nut.
good catch....didnt even notice...like i said..it shows you how the clamp works....good eye's
I see both of you guys are running modified hpop's should I be looking into one of those next spring turbo and injecters are getting upgraded hybrids and not sure on the turbo yet
You really need to do some datalogging of your ICP in your highest tune to determine if your hpop is up to snuff.
Well I don't have any tunes yet put when I do how do I log data like your saying ?
I do mine with my Auto Enginuity software. You can also check the hpop pressure with a guage. Look at the how-to secton here Swamp's Diesel Performance and it will explain the procedure.
How do you decipher injecters the 160cc 100% over what's that mean?
Is there anything special I need to know about taking off the fuel bowl?
Is there any good right ups on here on removing the fuel bowl and hpop?
Were would buy a evacuation pump for cheap? I've never needed one till now
I'm going to try too get the pedestal and turbo off today
I ordered the mechanics cabinet of orings along with fuel sleeves serviceable hpop plug motor to hpop gasket clay says I ordered every thing I need to fix my oil leaks do I need any taps for deleting the ebpv ? Clay sed some thin about taping one of the holes ? What kind of drill bit and tap do I need for the pyro sending unit and does anyone have a pic of where they put it in ?
Sorry for all the questions I'm just trying to learn as much about what I'm going to be doing before I do it hope fully every thing goes good
