transsmissions
Old Apr 29, 2010 | 12:55 PM
kentruckf100's Avatar
kentruckf100
transsmissions
Did for make the c6 to adapt to a 300?i have a c4 now but thinking about going witha c6 if i can what will i need for this i have a short wheel base.
Old Apr 29, 2010 | 01:07 PM
AbandonedBronco's Avatar
AbandonedBronco
As far as I know, the C4 and C6 and will swap without much of any issues. I think you'll need a C6 driveshaft yolk though.
Old Apr 29, 2010 | 01:17 PM
Rogue_Wulff's Avatar
Rogue_Wulff
Yes, the C6 was made to fit the small block bellhousing pattern. The 300 uses the small bellhousing pattern as the the 302/351W. These are fairly easy to find, as most pickups/vans from mid 70's to sometime in the 90's, that were equiped with a 3 speed auto, had the C6.
A C6 should be a bolt-in swap for a C4, though you may need to tweak the cooler lines a bit.
Old Oct 1, 2014 | 08:55 AM
kentruckf100
Old Oct 1, 2014 | 08:56 AM
kentruckf100
will this drive shaft work think one peace drive shaft its on c-4 now ? do not no weather its a one peace drive shaft or two.
Old Oct 1, 2014 | 08:58 AM
kentruckf100
Choppermike
WTB - Parts & other
Aug 15, 2016 07:29 PM
C-Doom-B-Jr
May 29, 2015 01:32 PM
miottimouse
Oct 17, 2014 07:32 AM
breakstuff
Aug 25, 2014 01:07 PM
dsrtjeeper
Jun 24, 2014 03:29 PM
