C6 temp gauge
Old Aug 24, 2014 | 08:53 AM
breakstuff's Avatar
breakstuff
C6 temp gauge
I have a 78 Bronco wondering where to put the prob for a temp gauge on a C6
Old Aug 24, 2014 | 09:13 AM
mikeo0o0o0's Avatar
mikeo0o0o0
Do you have a stock steel pan or aftermarket cast aluminum?
Either way, I would put it on the rear of the pan, towards the driver's side. There's nothing inside to interfere with the probe and putting it towards the rear will help protect it from being hit.
Somewhere in this area.
Old Aug 24, 2014 | 10:34 AM
Blue and White's Avatar
Blue and White
I plan to put mine in the pan also. Rear of the pan sounds good. This topic seems to get hotly debated time to time. From what I've seen/heard, pickup in the pan gives the most meaningful readings.
Old Aug 24, 2014 | 03:38 PM
rockittsled's Avatar
rockittsled
Makes sense to me, the hotter the fluid when it enters the works, the hotter it gets while working.
My question is where in the circuit does the fluid leave the tranny to go to the cooler and when it comes back, does it re-enter the circuit or dump into the pan?
that answer might change the preferred location
Old Aug 24, 2014 | 03:50 PM
mikeo0o0o0's Avatar
mikeo0o0o0
The fluid that goes to the trans cooler is the fluid that has flowed through the torque converter. It leaves the converter goes through the cooler and then dumps back into the pan.
The fluid out of the converter is usually the hottest, this is especially true if you're in stop and go traffic or towing heavy loads. The more slippage in the converter, the more heat.
That said, putting the temp probe in the trans cooler circuit isn't a good idea. While it is the hottest fluid, that's not the true operating temp. When the fluid is returned to the pan it mixes with the rest of the fluid so the temp averages out and this is the temp you need to keep an eye on.
What matters is the temp of the fluid that's going through the trans. and this is the fluid that's in the pan,
Old Aug 25, 2014 | 04:13 AM
rockittsled
Originally Posted by mikeo0o0o0
The fluid out of the converter is usually the hottest, this is especially true if you're in stop and go traffic or towing heavy loads. The more slippage in the converter, the more heat......... When the fluid is returned to the pan it mixes with the rest of the fluid so the temp averages out ...... What matters is the temp of the fluid that's going through the trans. and this is the fluid that's in the pan,
Thanks for the info, it confirms my assumptions
Old Aug 25, 2014 | 11:10 AM
breakstuff's Avatar
breakstuff
is there a test port where the prob can b installed or is the pan the best way to go
Old Aug 25, 2014 | 01:07 PM
mikeo0o0o0's Avatar
mikeo0o0o0
No test port, the pan is the way to go.
77460ford
Mar 31, 2019 12:25 AM
86-IDI
Feb 10, 2015 05:00 PM
stimm32
Apr 6, 2013 05:03 PM
packlet
Mar 8, 2007 10:07 AM
Malikenya
Dec 27, 2005 03:40 PM
