1998 4.6l windsor question
Old Apr 28, 2010 | 07:43 PM
donk18's Avatar
donk18
first off i am new here. hello to everybody and thanks for all help in advance. my issue is i am replacing my 4.6l windsor and have the same question everyone else has. how do i know if it is the six or the eight bolt? i have done all the research online and came up with noting. i tried to drop the oil pan like my mechanic told me to and i need to jack the engine to get that all the way down so that didn't work. i removed the cover to the flywheel i think. the small protective shield in front of the bell housing on the tranny. and i can see two bolts there. i belive those are the bolts that i need to see but i am not sure. my mechanic said that once i drop the oil pan i should be able to look up and see the bolts but like i said i can't get the oil pan.
Old Apr 29, 2010 | 01:18 AM
alloro's Avatar
alloro
I think you're looking at the wrong bolts. The 6/8 bolt question applies to the bolts at the center of the flywheel inside the red circle as shown in the picture of an 8-bolt flywheel below. (Ignore the 2 oddball holes, those don't count.)
motocrossross
Nov 4, 2014 08:39 AM
chard17
Modular V8 (4.6L, 5.4L)
Apr 16, 2014 05:33 AM
KY Thomas
1997 - 2003 F150
Aug 8, 2013 08:39 PM
exp1998
Jul 7, 2009 09:02 PM
92 Red F150
Jan 7, 2008 07:55 PM
