door code
Old Apr 28, 2010 | 08:22 PM
proudtruck's Avatar
proudtruck
Question door code
my parents just bought a 2006 ford expedition and it did not come with an owners manual was wondering if you could tell me how to get the code to the door lock combination to unlock the expedition
Old Apr 28, 2010 | 09:07 PM
fordtech08's Avatar
fordtech08
go to the dealership and ask them to use the computer to get it
Old Apr 28, 2010 | 09:19 PM
TexFinn's Avatar
TexFinn
Isn't there a sticker somewhere inside the passenger side kick panel?
Old Apr 28, 2010 | 10:26 PM
aft2005exp's Avatar
aft2005exp
I have a 2005 EXP bought used, and also 2006 250. Needed the codes for both key pads.. I believe the code is on a sticker located behind the center dash, radio area. If you look up at an angle from the drivers side floor, (use a flash light) you should be able to see it. It is pretty easy once you find it. Also, it may be upside down, There is a thread on here I think, or do a search for it on the net.
Old Apr 29, 2010 | 01:43 AM
alloro's Avatar
alloro
Look for a black module under the passenger side dash, next to the sidewall (kick panel) and behind a bunch of cables. It will have a white sticker on it with the 5 digit code being the larger numbers.
Tony Tobar
Sep 28, 2016 09:50 PM
outoforder
Apr 9, 2016 12:15 PM
RSCHAP1
Oct 27, 2015 12:59 PM
Dark Horse
28
May 22, 2015 09:56 AM
tk65
Jan 23, 2006 04:41 PM
