Sponsored by: Real Truck
Wandering truck
Old Apr 28, 2010 | 06:55 AM
ontariofarmer's Avatar
ontariofarmer
Wandering truck
I know this has been discussed before, but someone mentioned this the other day.
First my truck seems to wander right and left. The steering is REAL responsive. I have to watch that I don't over correct if it starts to go one way.
The suggestion someone made was that it could be the tires. There was a truck that was in this garage for the similar reason, the tires were replaced and the wandering was gone.
When we bought the truck the tires were near new.
Anyone ever heard of this before?
Old Apr 28, 2010 | 09:16 AM
senix's Avatar
senix
could be tires, try to rotate them. Also check for correct tire pressure. maybe up it or down it, but don't go less than the min or max pressure recommended.
You might also have incorrect tires for the truck. What are they? size?
Look at the cert label on the door pillar.
If none of this works then you may look at a steering stabilizer.
Old Apr 28, 2010 | 09:32 AM
DAVE67FD's Avatar
DAVE67FD
Confirm senix's ideas. The stabilizer could be at fault but doubtfull.
Give us some more history on the truck as far as mileage, upgrades, service repairs or similar. When was the truck last aligned?
You could have an issue with ball joints, tire rods, track bar bushings etc...
Old Apr 28, 2010 | 11:09 AM
ontariofarmer
The tires are Michelin LTX M/S LT265 75 R16 55psi in the front 70psi in the rear.
I had it at the dealer a couple weeks ago and they checked the front end and said all looks good.
I'm not sure when it had an alignment.
It has 126,000 KM or 78,000 MI
I think I'll try moving the front to rear and rear to front and see what it's like then.
Old Apr 28, 2010 | 11:21 AM
senix's Avatar
senix
E rated or D or C rated tires? Should be at least D since they are an LT tire.
Old Apr 28, 2010 | 02:16 PM
ontariofarmer
Load range E
Old Apr 28, 2010 | 03:33 PM
stickman89's Avatar
stickman89
wander
Your front u joints,my 05 did it thought I was gonna wreck.They get seized up from corrosion.
BCHauler
Aug 11, 2012 10:12 AM
XS29L9B
Feb 26, 2012 10:50 AM
dperez
Apr 18, 2011 09:35 PM
polscram
Feb 14, 2007 11:50 PM
jasonschwenk
Nov 30, 2005 08:34 PM
