1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
A/C compressor turning on when heat on?
Old 04-27-2010, 10:19 PM
cavitation's Avatar
cavitation
cavitation is offline
I lifted up the hood while the truck was idling today and when I turned the heat on I heard what seemed to be the A/C compressor turn on. The usual click noise that is heard when A/C is turned on. I turned the heat off and then on again and I could hear it turn off and on. I also felt a couple of the A/C steel lines and they were getting colder. I thought this was odd as the heat was turned on and blowing warm air in the cab. So, the truck heat and A/C works fine but my question is this: When you turn the heat on is it normal to have the A/C compressor become active or kick in? I never noticed it before but I never had the hood open when turning on the heat so perhaps I never heard it before. I know there are some A/C pros here. Just want to make sure I am not putting wear and tear on the A/C compressor if it is not supposed to become active when the heat is turned on. Thanks for the help.
Old 04-27-2010, 11:29 PM
SpringerPop's Avatar
SpringerPop
SpringerPop is offline
Normal operation.
The theory behind it is that the cold evaporator coil de-humidifies the air and speeds the defrost.
Pop
Old 04-27-2010, 11:59 PM
cavitation's Avatar
cavitation
Originally Posted by SpringerPop
Normal operation.
Pop
Thanks Pop. I take it that the compressor normally operates in any of the heat selections as well (defrost selection, under dash, dash only etc)?
Old 04-28-2010, 09:51 AM
dchamberlain's Avatar
dchamberlain
dchamberlain is offline
The a/c compressor runs in every position except heat on floor, vent and off.
Here is a thread where we discussed it and I found the relevant information in the service manual.
https://www.ford-trucks.com/forums/9...ompressor.html
Old 04-28-2010, 10:16 AM
cavitation's Avatar
cavitation
Perfect. I gave it a read and I think I got it. It appears that in all heat settings except "floor" the compressor kicks on WHEN outside air temp is above 43 degrees. My model year is a 2000 but I would imagine it is the same?
Taylor702009
04-24-2016 07:32 AM
kountzecobra
02-22-2016 08:38 AM
Kyle Horton
02-18-2016 02:07 PM
madsonp
1997-2006 Expedition & Navigator
10-11-2008 07:04 AM
DOUG5G
Aerostar
01-29-2006 06:47 AM
Quick Reply: A/C compressor turning on when heat on?
