missing, sometimes
Old Apr 26, 2010 | 03:46 PM
Flipstick's Avatar
Flipstick
missing, sometimes
I have a 2004 F250 Super Duty with a 6.0 diesel. This truck seems to be possessed. Sometimes, and I mean sometimes you can be going at highway speeds and the truck develops a "miss". If you accelerate more, it goes away, and then comes back when it gets to a certain load level. Now, there again, it doesn't do this all the time. Is there a simple fix, or a major fix. i am not a diesel guru, so basic English will help. I drive the truck daily, and tow a 4,500lb boat alot. I have a bully dog programer set to "tow". It also has an Airraid air box.
Thanks
Flipstick
Old Apr 26, 2010 | 03:58 PM
utjer's Avatar
utjer
Welcome to FTE! It would be great if you can list any mods you may have on your truck. That helps a lot sometimes. How often do you drive the vehicle?
Old Apr 26, 2010 | 05:55 PM
cartmanea's Avatar
cartmanea
How many miles are on it? Probably an injector getting weak, scanning for codes might show a cylinder contribution fault.
Old Apr 26, 2010 | 06:00 PM
69cj's Avatar
69cj
When was the last oil/oil filter and fuel filters changed? Are you using OEM filters? Have you checked for codes? Most here want to help but we lost our lease on the crystal ball.
Old Apr 26, 2010 | 06:01 PM
Flipstick's Avatar
Flipstick
miles
it has 98,000 miles
Old Apr 26, 2010 | 06:05 PM
bismic's Avatar
bismic
Does it have the "miss" with the stock programming?
Old Apr 26, 2010 | 06:07 PM
69cj's Avatar
69cj
Unless I missed it we don't know if it's tuned!
Old Apr 26, 2010 | 06:09 PM
bismic's Avatar
bismic
I believe he stated that he has his Bully Dog set to "tow" ....... (probably an addition from editing)
Old Apr 26, 2010 | 06:11 PM
Flipstick's Avatar
Flipstick
miss
I haven't tried without the programmer. Next time it does it, I will program it back to stock and see what it does. I am useing OEM filters and the oil was changed about 500 miles ago. The man that owned it before me use to put Cetaine additive into the fuel when he was at elevation or pulling something, he said that's what the dealership recommended. He said it worked most of the time.
Old Apr 26, 2010 | 06:15 PM
69cj's Avatar
69cj
My miss Mark, So, Sorry!
Old Apr 26, 2010 | 06:52 PM
tex25025's Avatar
tex25025
I don't know if the BullyDog has a decent code reader buil into their programmer or not. It's been a long time since I sold it to my farrier for his dodge, but hook that up and see if it's pulling a cylinder contribution code or not. It may not pick it up, if you have a better scan tool I would suggest using that.
I would think it's a fuel delivery issue. Either filters, fuel pump, or injectors. I think it was asked, but I don't recall seing the answers, when as the filters changed? I would do those first, then check for codes(if you have access to something better then the bullydog that would be the best, I just can't remember how extensive it is with code reading, some tuners are good, some aren't).
spurc
Jul 11, 2013 02:14 PM
rcm800
2009 - 2014 F150
Oct 25, 2012 06:05 AM
uarep
Mar 17, 2007 03:19 PM
trailerpuller
Oct 13, 2005 08:19 AM
trailerpuller
Oct 7, 2005 05:57 PM
