Need some help. Ordered wrong part
Old Apr 26, 2010 | 09:10 AM
redone1's Avatar
redone1
I ordered new turbo intake boots to replace my old orange ones. Now that i got them in I realized I definately ordered the wrong part.
I ordered this:
Silicone 45 Degree Reducing Elbow 3-3/8" to 3" 1820102C2: Intake Hoses, IntakeTubing, and Intake Clamps=
What i need are the orange boots that come off the turbo y-pipe to to the intake plenums. They are about 2.5-3 inches long. Does anyone know the dimensions on these?
If you could provide a link to the correct part on intakehoses.com that would be awesome. But just knowing the correct size boots would be very helpful. This is for a '97 powerstroke with stock turbo, plenums and no IC.
Thanks,
Pete
Old Apr 26, 2010 | 11:04 AM
JamesHajek's Avatar
JamesHajek
Yep, you ordered the piece for the intake that attaches to the turbo coming from your air filter. I believe these are what your looking for.
99.5-2003 Intake Manifold to Turbo Y Pipe Couplers
The link says 99.5-03 but click on it and it takes you to 94-97.
Old Apr 26, 2010 | 02:49 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
I ordered this:
Thanks,
Pete
If you havent upgrade the orange boot between the intake and turbo, you should with the boot you bougth, and James is right, and they are 2" ID.
Old Apr 27, 2010 | 01:46 PM
redone1's Avatar
redone1
I thought about this too. It appears that it has been changed as it's black, not orange. I cannot see any cracks or any wear that may indicate that it needs to be changed. The previous owner must have changed it out.
Also the boots that i ordered look to be the correct ones but are shorter than needed by a good two inches. So I'm sending them back and i've ordered the right ones yesterday.
Thanks for the info. James!
Old Apr 27, 2010 | 02:07 PM
JamesHajek's Avatar
JamesHajek
Hey no prob. Glad i could help.
Old May 1, 2010 | 01:30 PM
redone1's Avatar
redone1
Update. I got in the right parts and replaced them. Boy what a difference fresh turbo boots make! I was loosing quite a bit of boost.
Now i did notice today when working in the truck the two fuel lines underneath the turbo y pipe are in need of replacement. They run from the fuel filter to the fuel pump i believe. They don't appear to be leaking yet, but they are definately in need of replacement.
Anyone know where i can buy these??
Thanks for the help in advance fellas!
Old May 1, 2010 | 03:03 PM
Hussler's Avatar
Hussler
A few posts down in this thread are the part numbers ...
https://www.ford-trucks.com/forums/8...-write-up.html
Talyn
116
May 4, 2011 11:08 AM
Talyn
22
Mar 9, 2011 12:46 PM
Talyn
48
Nov 14, 2010 08:10 AM
rat49f6
Sep 9, 2010 04:30 PM
Knotwild
Dec 23, 2007 10:13 PM
