Smoke at start up
Old Apr 26, 2010 | 05:52 AM
ltl_jrw's Avatar
ltl_jrw
Smoke at start up
Heres the problem, I just had the oil changed and now when I start in the mornings I get bluish white smoke and a miss untill it warms up some. After that it will start great and no more smoke or miss. I put my AutoEnginuity scanner on and did a buzz test and all injectors sounded great and no codes that has to do with the problem. I did the buzz test when the engine was cold before the first start up. I dose start good but just smokes and then a miss.
Old Apr 26, 2010 | 09:15 AM
ron's power stroke's Avatar
ron's power stroke
if your sure you used the right oil test you glow plugs..
Old Apr 26, 2010 | 09:22 AM
Kwikkordead's Avatar
Kwikkordead
Yeah, sounds like a burned out glow plug to me.
Nothing at all to do with the oil change.
Old Apr 26, 2010 | 11:33 AM
ltl_jrw's Avatar
ltl_jrw
I'm sure they used the right oil as I watched them change it, Rotela 15-40.
I could be glow plugs so I will have them checked out. With one or two burnt out make it miss untill it warms up?
I am leaving Thursday for Alabama for about 4 mo's for work and am trying to get ducks in a row and that is not top of the list. Will be pulling my 35ft fifth wheer (14,000 lbs).
Old Apr 27, 2010 | 05:55 AM
Kwikkordead
Smoke and misfiring at idle until the cold cylinders that have the burned out glow plugs heat enough to ignite the fuel.
Old Apr 27, 2010 | 08:35 AM
DieselCamper01's Avatar
DieselCamper01
I wonder if that is my problem. Not overly cold lately and I still get a puff of smoke at startup. Hmmmm. May have to ohm those glowplugs.
Good luck in Alabama. Hope the truck runs great for you.
Old Apr 28, 2010 | 05:31 AM
ltl_jrw's Avatar
ltl_jrw
Thamks for all your help, when I get time I will check things out. Leaving tomorrow so it will just have to wait untill I get time.
540milotalon
Mar 18, 2013 11:12 PM
mrblonde108
Sep 19, 2010 12:11 PM
CPUNeck
May 13, 2010 09:16 PM
Ratkat
Jul 8, 2008 11:52 PM
millermanbg
Feb 6, 2008 11:07 PM
