C6AE-R Head Q's
Old Apr 25, 2010 | 09:43 PM
lt465's Avatar
lt465
Trailering
C6AE-R Head Q's
I have a set of c6ae-r heads on a motor in a 76 f250 i recently acquired, which supposedly has a 390. I wouldnt think those are the origonal heads for that truck or possibly whole different motor for that matter. I hear these heads are low-risers and are referred to as the poor mans cj head and am considering using them in my next build.
The thing i am curious about is if the headers off my d2te-aa heads will fit the c6ae-r's, and if the c6ae-r's have adjustable valvetrain?
thanks
Old Apr 25, 2010 | 11:41 PM
johnboy427's Avatar
johnboy427
In my book they are 66-67 352 heads and nothing to write home about. 71-74cc chambers and don't have adjustable rockers. Your D2 heads would be better because they already have hardened exhaust seats. Pretty sure the low risers are C3s.
-John
Old Apr 27, 2010 | 11:13 PM
Hypoid's Avatar
Hypoid
-John
After 36 years, I think the induction "hardened seat" is pretty much a moot point. He has heads with tall intake runners on a truck that never came with them from the factory. At this point the only two people who know for certain if the heads have hardened seats are the machinist who worked the heads, and who-ever installed them.
Also, from what I've read, and seen firsthand, 1966 was a pivotal year for the heads having the tall, "low riser" intake ports with open chamber, and the later "velocity ports" with "semi quench" chambers.
There are other sources I can reference, but they'd just take my lunch money.
To the OP: FEs are like a box of chocolates, you don't know what's inside until you open it.
I've read about problems with Hooker brand headers lining up on the later heads. I'm really pulling straws out my **** here, but I think the C6-R castings may fall into that category. Your best bet would be to pull one exhaust manifold and measure from the top and bottom bolt holes to the edges of the exhaust port. With that info, you can see where the header ports land by checking the same measurements.
Old Apr 28, 2010 | 10:49 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
If you mean posting links to information on certain other sites, have at it - that restriction has been lifted.
chiefsfootball
Nov 9, 2015 02:39 PM
tbirdscott
Sep 15, 2015 11:13 PM
72dumper
Aug 18, 2009 07:13 AM
Ford150/428/dud
Jun 30, 2009 05:46 PM
debestuss
Aug 23, 2004 11:24 AM
