not much
not much
hey guys new here great site. i have a 72 f600 dump tk with 330 HD and np435 32000 miles very good motor also VERY weak. i have had this truck for years always this way was thinking of new pistons maybe 390s and swaping to fe heads for 4bl and fe intake i have c6ae-r very low mile heads and msd dist for fe block vin # f60dvp41573 axle "f3b", trans "a" any advice?
Now I maybe mistaking, But a 330HD is a FT block, and if it is, you can NOT mix and match those with FE Parts, Other will be along to say if Im right about the 330, But otherwise, welcome to FTE and I hope you find all the help you need
very good motor also VERY weak. i have had this truck for years always this way was thinking of new pistons maybe 390s and swaping to fe heads for 4bl and fe intake i have c6ae-r very low mile heads and msd dist for fe block vin # f60dvp41573 axle "f3b", trans "a" any advice?D = 330 2V H/D FT Engine
V = Kentucky Truck Assembly Plant
P41573 = 1972
F3B: F3 = Eaton Model 15201 2 Speed Rear Axle // 6.33-1/8.81-1 // 15,000 lb. Rear Axle Capacity /// B = 5500 lb. Front Axle Capacity.
A = New Process 435 4 Speed
The 330 2V H/D FT engine uses the same cylinder heads as the 361 2V FT and 391 4V FT. The 330 2V M/D FT uses different heads.
All use the same head gasket....but it's not the same head gasket as an FE (352/360/390) engine uses.
32,000 miles? The odometers of these trucks read to 99,999.9 then return to ZERO...so the actual miles could be 32,000, or 132,000, or 232,000, or?
