6.0 trouble.. help
Old Apr 25, 2010 | 10:34 PM
rjbettini's Avatar
rjbettini
Rotella synthetic is what I used the last oil change and this time I used regular, that should not cause any issues right? How about coolant, just regular 50/50 green prestone?
Old Apr 25, 2010 | 10:46 PM
bismic's Avatar
bismic
No problems with the regular Rotella as long as it is CI4 or CJ4 rated.
Regular green coolant will cause problems. If you have it in your system it should be changed and THOROUGHLY flushed - immediately.
Old Apr 25, 2010 | 10:54 PM
rjbettini's Avatar
rjbettini
what should I use for coolant?
Old Apr 25, 2010 | 10:58 PM
bismic's Avatar
bismic
Post deleted!
Old Apr 25, 2010 | 11:01 PM
conger's Avatar
conger
niether, hey remember how I said in my original post it seemed to be worse after my oil change? I used Rotella 15w40 and a fram filter also fram filters for the fuel filters. any problems with them?
With that said, I'd be inclined to pull that filter out and see if it has come apart.
Old Apr 25, 2010 | 11:19 PM
rjbettini's Avatar
rjbettini
ok, dumb question... What filter??
Old Apr 26, 2010 | 12:07 AM
conger's Avatar
conger
Oil....Some aftermarket filters have been known to come apart and cause engine damage. Also what Bismic said. Get that green coolant out of your engine.
mbrule
Aug 6, 2014 11:02 AM
nodesy
Feb 23, 2014 10:54 PM
4x250cx
Nov 13, 2013 11:07 PM
trucker33
Mar 11, 2008 06:27 PM
KitsKid
May 24, 2007 08:16 PM
