Only possible additive is one that expands seals.
Otherwise could be a leaky injector. Check by testing for pressure leakdown from the fuel rail after engine shut down. Pressure should hold some minutes, then if not could be the fuel pump check valve but 'that' won't cause smoking.
Another possibility is a leaking fuel regulator diaphram allowing gas thru the vacuum hose into the intake.
