SMOKE
Old Dec 21, 2009 | 08:42 AM
1_BIGMOFO's Avatar
1_BIGMOFO
SMOKE
When I first start my truck in the morning ESPECIALLY when its cold outside it smokes like crazy!!
Its NOT black smoke, its like a whitish smoke and it smokes until it warms up then it goes away. It didnt start until I put the tuner on it and it got worse when it got super cold out..
Any help is appreciated.
Thank you,
Rob
Old Dec 21, 2009 | 08:52 AM
gearloose1's Avatar
gearloose1
1. cycle glow plugs twice.
2. use 5w-40 synthetic oil.
3. block heater.
Old Dec 21, 2009 | 09:04 AM
1_BIGMOFO's Avatar
1_BIGMOFO
I use Rotella Synthetic 5w 40 and i have the truck setup on a remote starter. Im sure it cycles long enough but not twice.
I am deff going to start using my block heater. That brings me to another ?
When my truck is plugged in can I start it with the remote starter for approx 20 minutes?
Thank you
Old Dec 21, 2009 | 09:06 AM
gearloose1's Avatar
gearloose1
Where are you and what is the coldest it gets at night?
Old Dec 21, 2009 | 09:15 AM
1_BIGMOFO's Avatar
1_BIGMOFO
Im in Upstate NY (Saratoga) it was below 0 this weekend.
Old Dec 21, 2009 | 09:17 AM
gearloose1's Avatar
gearloose1
Use block heater for 4 to 5 hours before start.
Use a timer if you want auto turn on/off.
20 minutes is virtually useless.
Old Dec 21, 2009 | 09:24 AM
rocknrotty's Avatar
rocknrotty
Keep a close eye on antifreeze level if it is dropping even a little then you know what the white smoke is.
check out head gasket and stud kits on this fourm
-R-
Old Dec 21, 2009 | 09:32 AM
1_BIGMOFO's Avatar
1_BIGMOFO
I was saying, leave the truck plugged in all night then start the truck while it is still plugged in for approx 20 minutes.. Will it hurt anything?
I usuall let is warm up for 20 min via remote start. but if i have to go out to unplug it the remote start is pretty much pointless
Old Dec 21, 2009 | 09:33 AM
1_BIGMOFO's Avatar
1_BIGMOFO
-R-
Dont you need to pull the cab to replace the gaskets / studs? Are there any other upgrades that can be done while doing this? Im considering it... Thank you,
Rob
Old Dec 21, 2009 | 10:09 AM
gearloose1's Avatar
gearloose1
Ahhh ok.
Warming for 20 min is too long --- you risk other things.
Warm it for 10 min is not bad...
Did you get latest flash that cures cold starting problems?
Old Dec 21, 2009 | 10:14 AM
1_BIGMOFO's Avatar
1_BIGMOFO
^^ I didnt know there was a flash to cure the cold start issue. Where can I get that?
Old Dec 21, 2009 | 10:47 AM
gearloose1's Avatar
gearloose1
Dealer and a crisp $100 bill.
Old Dec 21, 2009 | 10:54 AM
1_BIGMOFO's Avatar
1_BIGMOFO
I cant have the tune loaded on to my SCT Tuner from Eric?
Old Dec 21, 2009 | 10:55 AM
gearloose1's Avatar
gearloose1
Hey, if you are using tuners... you are on your own...
Call them and ask.
Old Dec 21, 2009 | 11:04 AM
1_BIGMOFO's Avatar
1_BIGMOFO
yea I have all custom tunes.. Im hoping the truck does NOT have a haed gasket issue...
