White smoke-missing
Old Oct 30, 2012 | 11:45 AM
Csymons's Avatar
Csymons
White smoke-missing
Hello, I have a 94 F350 crew 7.3 idi turbo. Great truck. I have a lot of smoke at cold start and it still smokes quite a bit as it warms up and doesn't really go away. It seems to sound like it's missing when you get on it but not really at idle. Still has a lot of power but curious what people here think it is. I have dumped a bunch of howes, power service (gray bottle) and even dumped a quart of atf in. Any help would be great thanks in advance.
Old Oct 30, 2012 | 11:48 AM
hairyboxnoogle's Avatar
hairyboxnoogle
Right off the top of my head, injector sounds likely.
Old Oct 30, 2012 | 11:51 AM
Csymons's Avatar
Csymons
Should I get injectors and kit at Ford or online somewhere?
Old Oct 30, 2012 | 12:13 PM
hairyboxnoogle
There is a few members on here that do injectors, might wait for one of them to chime in. Also, might wait for a couple other opinions.
Old Oct 30, 2012 | 12:21 PM
bashby's Avatar
bashby
A lot of people have had trouble with buying injectors online, never heard of anyone getting them from Ford. When I replace mine I plan to get them from Russ, username Typefour on this forum. From what I understand he pop tests injectors before they go out, so you get a matched set that all work. He alsoo sells install kits with the o rings and return lines. Try sending him a PM
Old Oct 30, 2012 | 12:26 PM
Skip1970's Avatar
Skip1970
some forida diesel place send me mine and they were 135$ with the rubber line and t kit, no core.. look for them online.
Old Oct 30, 2012 | 12:53 PM
bashby's Avatar
bashby
Conestoga Diesel in Pa has a good reputation.
Old Oct 30, 2012 | 08:41 PM
Csymons's Avatar
Csymons
Excellent thanks everybody.
Old Oct 30, 2012 | 08:51 PM
jdstudski's Avatar
jdstudski
could be a bad ip. my 89 7.3 was smoking at ton at idle and a fair amount at speed along with losing prime and missing so i replaced the injectors which fixed the prime loss and miss but the smoke didnt go away until i swapped the ip for a reman. we are talking white smoke, right?
Old Oct 30, 2012 | 09:03 PM
Csymons's Avatar
Csymons
Yes it is white
Bigoford
Dec 12, 2013 11:52 AM
Ford_250
Mar 18, 2011 06:49 AM
indyF-350psd
Dec 2, 2010 07:29 PM
mhenneboehle
May 6, 2009 09:07 AM
Brimhall
Dec 31, 2003 09:36 AM
