You can correct me if I`m wrong but you are correct for RABS1 but I think RABS2 does store codes.
Right? Wrong?
I'm sure my '87 is old enough to have RABS1 and it does not store codes, so I had that on my brain. I'm not very familiar with RABS2, so I assume you are correct about the code memory. When did Ford make the switch to RABS2?
EPNC, my `87 is RABS1 also and does not store codes. The ABS light has to be on before grounding the diagnostic connector and as you say all codes are lost when the ign switch is turned off.
AS I understand it RABS2 was introduced around `93 (but could be wrong, may be later) and does store codes.
wow noone else with any info hasnt anyone ahad to deal with a problem like this?
Code 4 is generated by the module's detection of a resistance falling below 18k ohms (short) or above 26k ohms (open) in Circuit 535 (LB/R). This can indicate an open or short in the reset switch circuit, or a hydraulic leak into dump section of the valve.
Possible Contributing Base Brake Component/Vehicle Wiring Concerns
Terminal backout in the module harness connector at Pin 6
Terminal backout in the RABS valve harness connector at Pins 2 or 3
Bulkhead connector (between engine compartment and instrument panel) terminal backout or loose connection
Module or RABS valve connectors not fully matted with component
Intermittent open or open circuit in Circuits 535 (LB/R), or 274 (BK/W)
Intermittent short or short circuit in Circuit 535 (LB/R)
Defective anti-lock brake control module
i really dont know and ford is a dumb *** for putting abs on the rear any way it should be on the front
If ABS is implemented on one axle only, the rear is where it must be - never only the front axle. Ford would have had a few million lawsuits and a big recall if they had done front-only ABS. If the rear end locks while the front has grip, the vehicle will swap ends very easily. Rear-only ABS keeps the rear end in line (when working properly, obviously), even if the front end locks up and loses grip. Four wheel ABS gives the most driver control in maximum braking situations, but rear axle-only ABS is a decent compromise, especially for the technology available 23 years ago.
