abs lite on
Old Apr 25, 2010 | 11:42 AM
njtinman2's Avatar
njtinman2
abs lite on
i have a 94 f150 4x4 and the abs lite and brake lite are on how do i pull codes and where is the connecter and what are the code deffintions?
Old Apr 25, 2010 | 01:38 PM
Lazy K's Avatar
Lazy K
there was a thread here a few weeks ago on pulling the RABS codes, if you do an advanced search you may find it.
There should be a black wire with an orange stripe behind the glovebox, disconnect it from the black wire and with the light on ground the wire. The light should start to flash the error codes.
However as both lights are on together I would say to check the brake fluid level and also the wiring connector at the master cylinder for corrosion/loose. It is also possible you have a bad fluid level sensor.
Hopefully some of the experts will chime in soon.
Old Apr 25, 2010 | 03:43 PM
njtinman2's Avatar
njtinman2
pulled codes and got code 4 over and over so now what any ideas?
Old Apr 26, 2010 | 04:36 AM
Lazy K's Avatar
Lazy K
According to my list code 4 is "open/grounded valve reset circuit". Also something I did not know, it is the only fault that throws a code that will turn on both lights.
Have a look at the wiring plug connector at the RABS module (on inside of left side frame rail). Check that there is no corrosion and that it is tight.
Old Apr 26, 2010 | 08:15 AM
njtinman2's Avatar
njtinman2
i will try that thanks
Old Apr 27, 2010 | 07:23 AM
njtinman2's Avatar
njtinman2
the wire and the plug are in very good shape no corrosion no brakes in the wires the plug is clean
Old Apr 27, 2010 | 09:38 AM
Lazy K's Avatar
Lazy K
It was a long shot at best. One other thing you could try (another long shot) is to flush new brake fluid through the rear brakes and clear the code and see if that helps.
Failing that the only solution may be to replace the RABS module but that is quite a lot of $ to spend without certainty of a fix.
Old Apr 27, 2010 | 12:59 PM
jas88's Avatar
jas88
IMO the RABS on these trucks is dangerous and worse than having nothing at all. I have had 3 of this vintage and a 2000 SuperDuty that was in the same boat, I always pull the ABS fuse and also the ABS warning bulb and go on down the road.
Old Apr 27, 2010 | 09:25 PM
njtinman2's Avatar
njtinman2
i just put new lines on the rear so it just got flushed how do i clear the code?
Old Apr 28, 2010 | 04:22 AM
EPNCSU2006's Avatar
EPNCSU2006
The RABS computer has no memory, so the codes get cleared every time the truck is turned off.
Old Apr 28, 2010 | 04:31 AM
Lazy K's Avatar
Lazy K
There a couple of ways to clear the code. If I remember right (and I may not) if instead of grounding the diagnostic wire (the one that starts the code sequence) you momentarily ground the other one the codes will be erased.
Second if you lift the negative battery terminal off for 5secs the codes will be erased. If you have a security coded radio it will loose its code also doing this.
Old Apr 28, 2010 | 04:34 AM
Lazy K's Avatar
Lazy K
We must have posted at the same time.
You can correct me if I`m wrong but you are correct for RABS1 but I think RABS2 does store codes.
Right? Wrong?
Old Apr 28, 2010 | 05:29 AM
HrdDrv's Avatar
HrdDrv
If my rig sits overnite in damp weather, the first time or two I hit the brakes, the rear locks up. Also, sometimes during normal dry weather stops, the ABS will activate. I don't like rear ABS and am also thinking of doing away with it.
Old Apr 28, 2010 | 06:01 AM
bigbasshb's Avatar
bigbasshb
Here's a little thing that happens to me every time I do brake work on my 92. The floats inside the master cylinder reservoir get stuck down. Have you tried pulling them up manually? I use a set of needle nose pliers or even a pencil if pliers aren't available.
Good luck.
Old Apr 28, 2010 | 11:34 AM
njtinman2's Avatar
njtinman2
the float is fine it is floating plus it is a code 4 and has nothing to do with the float
