Sponsored by: Kumho
abs
Old Nov 27, 2006 | 05:09 PM
divedigger's Avatar
divedigger
abs
I have a late 99 f350 psd. The abs lite is on and the brakes are not working correctly. The code on my tuner read P0603* internal ctrl mod KAM error. Can anybody interpet this and give me an idea where to go next and what to do?
Thanks for any info! divedigger
Old Nov 30, 2006 | 05:38 AM
SRD4X4's Avatar
SRD4X4
P06** codes are ECM related,KAM= Keep Alive Memory.ABS codes should start with a B or C.What's wrong with the brakes?
Old Nov 30, 2006 | 07:25 AM
divedigger's Avatar
divedigger
I found out it was the rear end sensor, replaced it for 18.00 it cleared the code and the brakes aer back to normal! Thanks for all the info and help! Divedigger
Old Nov 30, 2006 | 09:52 AM
projectSHO89's Avatar
projectSHO89
From the PCED:
MA1 CONTINUOUS DTC P0603 IS SET WHEN THE PCM HAS LOST KAPWR
NOTE:
This code may have been caused by disconnecting the PCM or the batteries.
l Possible causes:
-- Battery or PCM has been disconnected.
-- Battery cables loose or poor connection.
-- Battery discharged.
-- Open in KAPWR circuit.
-- Blown fuse.
-- PCM.
l Check for other codes.
l Key on, engine off.
l Clear DTCs.
l Cycle key off, then on.
l Perform retrieve Continuous DTCs.
l Was DTC P0603 present?
Yes
GO to «MA2».
No
Intermittent failure, unable to duplicate. REPAIR other DTCs as necessary. If none, testing is complete. RESTORE vehicle. CLEAR DTCs and RETEST.
The ABS rear diff sensor fault should not, in any way, have affected you normal hydraulic brakes.
Steve
Old Nov 30, 2006 | 05:57 PM
divedigger's Avatar
divedigger
Was that last two sentences in your reply meant for me? Thanks
Old Nov 30, 2006 | 07:55 PM
projectSHO89
Nope. That's just my signature..
"Can't fix stupid" ...Ron White
Old Nov 30, 2006 | 08:05 PM
divedigger's Avatar
divedigger
Thanks for all info! Divedigger
Boyd'z Toy
Mar 26, 2013 08:18 AM
Beastlyforddude
Feb 16, 2011 01:54 PM
clipnclop
1997 - 2003 F150
Jul 9, 2007 08:45 PM
mgriffin
Mar 20, 2002 05:40 PM
