400 oil capacity
Old Apr 24, 2010 | 04:25 PM
clhart426's Avatar
clhart426
400 oil capacity
this has been a topic before and cant find it again. i have a 400 in my 78. i cant remember what the oil capacity says its supposed to be, but that when you fill it to spec. it still doesnt show on the dip stick. so how much oil does one of these beasts need to have in it?
Old Apr 24, 2010 | 05:06 PM
radar457's Avatar
radar457
unless you have a different pan than I have all mine take about 5 to 5 and a half qts. You sure you have the correct dipstick...
Old Apr 24, 2010 | 05:20 PM
tinaheels's Avatar
tinaheels
its 5 quarts + 1 quart for the filter
Old Apr 24, 2010 | 06:56 PM
mark a.'s Avatar
mark a.
If its a factory rear sump 4x4 pan, my old 400 held 6 1/2 qts with a new filter.
Old Apr 24, 2010 | 07:31 PM
82ford302's Avatar
82ford302
agreed. had a 79 f150 4x with a 400 that took 6 to 61/2qts with filter. just depended on how long i waited for the oil to drain in the crankcase and my patience. should be 6qts with filter factory but you never know.
Old Apr 25, 2010 | 10:36 AM
clhart426's Avatar
clhart426
yea jbgs book says 6 quarts, but hardly even reads on the dip stick, and was the same out of the old 400 i had in it before it died. ill just keep it at 6 1/2 qts and call it good ha
Old Jul 29, 2018 | 11:24 PM
thedanflan's Avatar
thedanflan
Question Oil Issues (both capacity and pressure)
Howdy folks,
I am finishing up a '79 clean up with a 400m. I have been having super low oil pressure with a mechanical gauge (pegging 0 at idle after warm, but rising with RPMs) and lost the dipstick somewhere along the restoration. Right now I have 6-1/2 quarts of 10w40 in it and then half a quart of Lucas Oil. The Lucas brought my startup oil pressure up. I have no idea what the capacity is. I have seen so many different numbers, from 5-1/2 to 9 quarts. It is a 2wd and the oil pan looks nice and normal. Would love any suggestions or help. Thanks!
Old Jul 30, 2018 | 09:26 AM
ranger140892's Avatar
ranger140892
Grumpy goat
Yep, 79 owner's manual says 6 quarts for 400, 4wd. With oil and filter change, mine takes 7 quarts to get in on the mark.
Old Jul 30, 2018 | 12:29 PM
mark a.'s Avatar
mark a.
Originally Posted by thedanflan
Howdy folks,
Did you put a new sender on it ? When they go bad they can read low.
Old Jul 30, 2018 | 01:19 PM
hivoltj's Avatar
hivoltj
6 quarts with filter
Old Jul 30, 2018 | 11:23 PM
1TonBasecamp's Avatar
1TonBasecamp
He said his is a two-wheel drive. Does that make any difference? Or is a 400 a 400 and no matter what chassis, it's still 6+ quarts?
Did the 2wd trucks come with 400's from the factory? If not it might be a car pan, if that's different (which they usually were back then) and the dipstick is in the front of the block vs the pan?
thedanflan, is the engine rebuilt or are you running it as-is and you're just cleaning up the truck itself?
If it's an older engine, that low pressure could be legit. Be nice to run that mechanical gauge on another vehicle just to verify the pressure readings though. Big pain in the butt, but would be nice to have some sort of confirmation that the gauge is reading properly.
Good luck.
Paul
Old Jul 30, 2018 | 11:59 PM
thedanflan's Avatar
thedanflan
Good luck.
Paul
The 4x4 pan was smaller from everything I have read. Supposedly the 2wd had bigger pans. Running it as is. Just did a good ATF clean flush so that the oil is clean, swapped the 2 barrel carb for a 4 barrel EFI, and put a big ol 4 row radiator on it. I have tried multiple mechanical gauges and tried this one on my buddies 460. Read good. I am more concerned with the capacity than the oil pressure. Not much I can do if the 400 is just plain worn. Also the 400 was from factory
automaticlee
Oct 5, 2016 07:38 PM
Jlmenz
401, 477, & 534 SD Engines
Feb 26, 2016 09:08 PM
Blue Oval Consumer
General Diesel Discussion
Jan 18, 2014 07:39 PM
fordman400
May 6, 2010 08:40 AM
xlman
Oil & Lubrication
Jan 5, 2007 08:07 PM
