I've read in some of the Ford manuals in the tech folder that a new FICM doesn't come programmed. So if I buy one from Ford will I need to install it and then drag it to the shop to be programmed?? If I get one from one of the aftermarket companies, will it arrive programmed?
Originally Posted by hrkdrivr
Just checked the shop at work; they have a variable-temp soldering iron. What temp is good for re-floating solder?
I got a little overzealous removing the amber glue stuff and stripped the covering off some of the capacitors (?) on the board. Is this a problem (have I removed some electrical insulation?) or is the covering just a labeling/identification method? If it is a problem, can I just replace the amber, non-conductive stuff to seal them bck up?
Reading through the FICM repair procedure, you're supposed to re-flow some solder connections. I don't see any cracked or broken solder. Is it possible reflowing will still help?
