Turbo upgrade
Old Apr 22, 2010 | 07:29 PM
CanadianSmokie's Avatar
CanadianSmokie
Turbo upgrade
I asked this in the General Diesel section but thought I'd post it here as well as this gets waaaayy more hits.
I was talking to an International diesel tech a couple of years ago and he mentioned to me that the turbo's on the T444E International school buses were larger than what Ford put on the 7.3.
My question is, can anyone confirm this and is it possible to swap the turbo from the T444E onto our 7.3's?
Thanx...
Old Apr 22, 2010 | 08:21 PM
canister's Avatar
canister
I think this is what your talking about.
International T444E 7.3 Diesel Turbo 1999-2003 : eBay Motors (item 250614959450 end time Apr-23-10 16:02:31 PDT)
I'm probably wrong but it looks the same as a van turbo. I'm sure someone can give a little more info on it.
Old Apr 22, 2010 | 08:24 PM
gasgrunt88's Avatar
gasgrunt88
Yeah, it's got the 1.15 A/R exhaust housing so it looks about the same as a van turbo to me...
Old Apr 22, 2010 | 09:00 PM
lfthrdr's Avatar
lfthrdr
I am a fairly new "newbie" here on FTE, but I have an 01 Excursion 7.3 which we mostly use for towing our 30' travel trailer. What does a different turbo actually do for our motors (van turbo or the one mentioned here used on busses)? Is it worth the money? If you upgrade the turbo do you have to upgrade other parts as well? Are these reconditioned ones OK to buy?
Old Apr 23, 2010 | 06:53 AM
Izzy351's Avatar
Izzy351
A van turbo has a different, slightly larger exhaust wheel, and a much larger exhaust housing. What it does is favor the top-end of your RPM range greatly. It will reduce your EGTs at WOT by about 200 degrees, and helps reduce surge. However, it will be a lot more laggy spooling up than the stocker, ESPECIALLY on stock tuning. In fact, I wouldn't even consider running the van turbo on stock tunes, so if you decide to go with a van turbo, it will require some other mods to support it (intake, exhaust, gauges, & tunes as a minimum).
Walleye Hunter
Jul 27, 2016 11:20 AM
Vinford
General Diesel Discussion
Jun 17, 2016 01:15 PM
Bird-Dog 250
Jan 12, 2016 01:04 PM
WA_PSD
24
Mar 19, 2013 07:36 AM
FordMan1981
Jan 19, 2013 02:03 PM
