GT40P heads are better than stock 351 heads but I'm not sure where you could buy
them other than at a dealership. If you get used ones they would probably have to be
reconditioned which would cost money. I like Dart cast iron cylinder heads for small
block Fords. They come fully assembled with a performance valve job and springs to
match most cams you would want to use. I don't sell or have anything to do with them
but have used them in the past with good results. They can be purchased at Summitt
or Jegs and for a while aleast a few years ago from Ford Motorsports catalog. I would
at least do a cost comparison if you are seriously looking at cylinder head replacement.
Great call- if you really want to put the motor in a new league, you're going to have to throw out the factory heads. I vote for Edelbrock heads, the Performer RPM aluminum come ready to bolt-in and will make the engine capable of 300+ HP. Airflow Research makes a great head too, probably the highest performing one, but for fit & finish and everyday reliability, Edelbrock stuff is better than stock every single time.
Conanski's going to have to help you out with the SD issues- I've only dealt with carbureted V8's!
Changing out heads would be an $1,800 project (not counting the SD upgrades that will probably have to happen), but you can get a very large realistic power increase. It doesn't sound like that's the direction you want to go, but just keep in mind that if you want serious power it's going to involve everything except the short block.
Is our exhaust config. exhaust manifolds, ypipe, into cat, into small resonator into large muffler then just a single outlet? and how many o2 sensors and location?
I used the World Windsor Jr's in the past and they were great. The next 302 I build will be wearing Edelbrocks or AFR's though. I was at first scared of an aluminum-headed engine, but keep in mind that gasket technology has come a long way since bi-metal engines first came out, and especially if you do it right with ARP fasteners and Fel-Pro gaskets you'll never have an issue with sealing.
The GT-40p's are cheaper than most aftermarket heads, but if you make the decision to upgrade your heads there's no reason not to spend the money while you're in there.
The best advice I can throw out there is to be realistic with your expectations and always keep in mind what the purpose of the truck is. There's not a lot of "cheap power" out there to make. Also, if the truck is a daily driver then it's almost certainly not worth taking the top end apart when it works fine the way it is.
Cylinder Heads
I agree about shopping around, for about 200 dollars a piece assembled that aint to bad. the only thing I can think that you have to do to put em on is have the 7/16 head bolt holes enlarged to 1/2.
I was just curious why in the past have you have said that long tube headers are the way to go? Is this setup just a bolt up kit or will there be fab work involved? One last thing how many o2 sensors are on our trucks and are they located before and after the cat converter?
Longtubes are king form a performance standpoint but there are no over the counter Y pipes to put them on these trucks you have to build your own. In comparison the shorty header setup mentioned is a relatively simple bolt-on affair. These trucks have a single O2 and it is before the cat, the Bassini and Magnaflow Y pipes will have a bung for this as will some of the headers, and smog legal headers will also have a bung for the EGR tube.
If I put that cam in and shorty headers and keep the factory exhaust oh and rocker arms what kind of gains do you think i will have
the last engine I had in my f350 was a 351 that operated on sd, It had a rv cam in it, dont think it made much difference in hp, but torque was a world of difference, idled nice and being able to blow the 35s off at 25 mph was a nice feeling.
Where could I get an rv cam like you re talking about
Thanks,
I like Dart cast iron cylinder heads for small block Fords. They come fully assembled with a performance valve job and springs to match most cams you would want to use.
Incidentally I have a set of Dart Iron Eagles for my 5.8 build, got them complete with 0.550" lift springs and 2.02/1.60" valves for $1250. RHS is another company making iron heads for these motors that cost about the same, on paper both these heads perform nearly as well as aluminum AFR heads which cost significantly more.
I didn't get a decibel reading before and after, but it's not any louder at all. You're right about it being quiet- before and after it's still not as loud as the fuel pump!
I called Flowmaster and that's exactly what their tech said to do. I told him I had an inline-6 and wanted the efficiency but none of the sound and it turned out to be exactly what I wanted!
I used to have another 95 F150 with the 4.9 and had a 50 series Flowmaster with a turndown on it for a little while. It was louder than the stock exhaust system.
As was already stated, the Bassani or Magnaflow Y pipe and a good muffler like Magnaflow, Dynomax, etc will give you a good exhaust system. Just run a 3 inch single exhaust. Many have done that with good results and you can put it together yourself. I forgot what tail pipe they used, but I think it was easy to get as well. If you want duals just get a SIDO muffler.
You can get a rv, or tow haul cam from either summit or comp cams, I believe isky cams also manufacture one. Heres a link to comp cams COMP Cams: Magnum
You seem to be the guru when it comes to a lot of the motor questions I've seen on here, and I've got some questions for you based on your experience. Is there a better way of contacting you other than here? Questions based on 94 351w roller, gt40 heads, cam and the computer. Got a smokin deal on damn near new heads, so trying to figure this out.
