my 96 tranny it shifting REALLY LATE...... what do i gota do to stop it.... its an automatic and im using the column to shift..... i know that aint right. i got a 302 with the ed04? i think thats what its called
More than likely not the transmission.
You need to have the codes read in the computer to see if you have a bad TP, TR, VSS input or the shift solenoid pack.
i replaced the tranny 6 months ago it has fresh tranny fluid threw out the whole tranny. and my computer input thing is busted i cant read the codes, ive tried to have auto zone try it and the computer says nothing, but my check engine light is on sooo......
If it is not the solenoid pack then it sounds like either the TR sensor is bad or the speed input to the computer is missing.
You can check the TR sensor with an ohm meter at the computer plug. The speed input is a little harder as you would have to look at the output from the PSOM with a scope or a meter on the AC scale.
You could also try unplugging the RABS and the Speed Control modules and see if is OK then.
What is your Speedometer needle doing, is it steady?
