Best Engine for 63 Flareside
Old Sep 18, 1999 | 12:09 AM
63Bruce's Avatar
63Bruce
I currently have a 361W engine with no modifications in a 63 Flareside Custom Cab. The engine is obviously not stock. I am looking at beefing up HP. I can purchase a 351C block and heads at a good price. Should I go with the C and rebuild it, or should I rebuild the W engine? The W is currently a 2bl, and I could add cam, headers, intake and a 4bl. I am looking for any and all suggestions, including building for a different block entirely. I want a sound motor with high HP, and fuel economy (yuk) is not an issue. The original 3sp manual on the column has been swapped for an auto on the floor. Let me know if you have any suggestions. Thank You!
Old Sep 18, 1999 | 09:04 AM
john's Avatar
john
Do you mean 351w?
Do you mean not original?
I would suggest the W, it is a very reliable engine and a lot more current, with a ton more options/parts available.
If you plan an overhaul zero in on your budget and go from there. You could expect to spend at least $2000.00. If you have deep pockets $4000.00 can be reached fast.
John
Old Sep 20, 1999 | 08:16 AM
Bill's Avatar
Bill
I have a 70 351W in my '64.. got it from a guy who put a 351C in his 77.. he wants the W back.. nothing wrong with the C even in the two barrel form, but the W develops torque earlier therefore is a bit more streetable for a daily driver, if that is your preference...
Mine is currently being rebuilt at a trusted speedshop and is going to run me about $2000 for a better than stock rebuild.. we are shooting for about 300-325 hp.
Just my thoughts...
good luck..
Bill
Old Sep 20, 1999 | 12:56 PM
Bruce Kling
Guest
Posts: n/a
Thanks for the info. Is there any place I can look on the motor for a number that would help me figure out how old the motor is? Thanks again.
Old Sep 20, 1999 | 10:54 PM
63Bruce's Avatar
63Bruce
63flareside
Ford Truck Parts for Sale
Dec 16, 2017 04:41 PM
schweinhaus
Jul 23, 2014 02:42 PM
Tenor
Mar 17, 2004 09:16 AM
bigredvan
Feb 20, 2004 02:27 PM
bigredvan
Feb 14, 2004 09:29 AM
