IP leak
Old Apr 21, 2010 | 12:21 AM
Bluecrew250's Avatar
Bluecrew250
IP leak
7.3 94 turbo My Injector Pump is leaking were the fuel comes in at the back of the pump I was wondering if the seal could be replace with the IP in the truck or if I have to take it off to do it And if so does the IP have to be timed to take it off
Thanks
Old Apr 21, 2010 | 10:16 AM
wreckinball's Avatar
wreckinball
Where the fuel comes in at the back of the pump? Can you clarify with a pic or use vehicle part references? The fuel comes in at the "front" in the middle hard line so i am a tad confused. Thanks
To answer the rest, if the IP is removed, yes timing will need to be reset. I am not sure if it can be done with the IP in the truck as i dont know where you mean!
Old Apr 21, 2010 | 12:50 PM
Festus Hagen's Avatar
Festus Hagen
Methanoholic
Don't pull the pump without first asking questions, peeps on here can walk you through it resulting in a better job easier!
Fuel comes in the rear of the IP, From the Filter head via a 5/16" steel line that is sealed with 5/16" Parker Vibra-Loc seals.
Dieselorings.com usually has them, I cannot find them on their site. (They show 1/4" ones)
McMaster-Carr has 3/8" for the Lift pump to Filter 3/8" Vibra-Loc Seals, However I have never been able to find 5/16" ones there. If someone has please forward info.
You do NOT need to pull the pump to replace them.
-Enjoy
fh : )_~
Old Apr 21, 2010 | 07:47 PM
Bluecrew250
Thanks Festus
Onus
18
Oct 4, 2012 07:39 PM
joe f350
May 29, 2011 07:21 PM
deceptichop
Feb 27, 2011 07:52 AM
4drf350
Feb 2, 2011 11:51 AM
jeffdoerr
22
Dec 15, 2005 02:01 PM
