Sponsored by: Real Truck
Squeaking noises
Old Apr 20, 2010 | 09:20 PM
elkhunter4life's Avatar
elkhunter4life
Squeaking noises
Hey ya'll just wondering if i can get some help from some ford lovers like myself? My truck has been having issues and just had a brand new motor put in it. I just got it back from the shop and now when even sitting in the driveway it squeaks when the tires are turned i have tried just about everything i can think of! Anything can help and thanks for the input!
Old Apr 20, 2010 | 11:34 PM
rayrayyj's Avatar
rayrayyj
Going to need a better description...ie. where is the sound coming from. When my ball joints were shot it made the most aweful sound standing still while turning the wheel. Is this a sound from the engine or just from the front end or what?
Old Apr 21, 2010 | 12:05 AM
BigPigDaddy's Avatar
BigPigDaddy
It looks like you have a '99 SD, so squeaking could be many things, but ball joints are likely to be suspect if they haven't been replaced.
Old Apr 21, 2010 | 09:22 AM
elkhunter4life
It is a 1999 F-250 Superduty, This sound is coming from the front end only it sounds like it is coming from the tie rod ending on the passanger side but i have replaced all of that and its still making the noise. It almost sounds like something is just out of grease but everything was just toped off so im just stumped thanks for your help guys!
Old Apr 21, 2010 | 10:20 AM
Zedrive's Avatar
Zedrive
Is your belt slipping.
Just a heads up. If you are not moving and turning the wheel your stressing your steering system. Have you never driven a car with arm strong steering.
Old Apr 21, 2010 | 10:43 AM
rayrayyj's Avatar
rayrayyj
What all did you replace? Just tie rod links or were the ball joints, all 4, replaced? If you still have some stock ball joints in there that is my guess. When mine started to go it sounded bad and I thought maybe just some grease on the tie rods....did nothing. Replaced all 4 ball joints and good as new, no more nasty sound when turning.
And just as a side note, when I jacked up the front end to hear the sound it wouldn't make it - only when grounded.
Old Apr 21, 2010 | 07:31 PM
elkhunter4life
hey thanks guys much appereaciated; replace both tie rod ends and ball joints all 4 of them and its still having troubles not near as bad as it was but still doesnt sound good. Zedrive the belt is doing good no slipping.
Truck55
1997 - 2003 F150
Jul 29, 2012 08:17 PM
WickedSharp
Jan 13, 2011 09:10 PM
Adad2girls&aTruck
1997 - 2003 F150
Jul 27, 2007 07:42 AM
P95Loser
1997 - 2003 F150
Apr 29, 2007 10:55 PM
razor_jim
Aerostar
Apr 27, 2004 09:15 PM
