Sponsored by: Real Truck
Tranny fluid questions
Old Apr 18, 2010 | 09:40 AM
calvinjwilcox's Avatar
calvinjwilcox
I recently did a tranny flush on my 2005 F350 PSD. I changed the internal and external filter and filled it with 9 quarts of Mercon SP. When I checked the dipstick I couldn't tell if it was overfilled or under. Can anyone tell me how they check their fluid? Is 9 quarts too much? Any help would be appreciated.
Old Apr 18, 2010 | 09:46 AM
Ace!'s Avatar
Ace!
How'd you do it, just drop the pan, or was it "flushed" with a machine?
Old Apr 18, 2010 | 09:51 AM
calvinjwilcox
Thanks for the reply. I went the cheap route and dropped the pan. I initially added 6 quarts and gradually added 3 more. Now I can't tell if it's too much or not. I definately don't want to screw anything up.
Old Apr 18, 2010 | 12:50 PM
Mud-and-Guts's Avatar
Mud-and-Guts
I am fixing to drop the pan and do a filter swap my self and the Ford dealer told me 8 quarts on my 99 f-250 V10..... But I plan on purchasing more just incase....
Did you use Mercon V?
Old Apr 18, 2010 | 01:23 PM
calvinjwilcox
I used Mercon SP for mine . The dealer told me that if I'm just dropping the pan and changing the filters it would take anywhere from 6-8 quarts of oil. I'm at 9 now and it looks like it's at the right level. I have a TorqShift 5r110 tranny and you probably have something different....i think the 4r100 so it takes a different type of fluid. It should say on your tranny dip stick.
Old Apr 21, 2010 | 02:33 PM
Mud-and-Guts
I changed my tranny filter yesterday on my 99 f250 Super Duty Lariat and it took 7 quarts to top it off when just dropping the pan. I got to say this was the cleanest I had ever dropped a pan due to the factory drain plug.. I guess ever 3-4 oil changes I may pull the plug and change the fluid.... They are not joking about the trans pan gasket being reusable either it is the best built gasket I have ever seen. I purchased a new gasket and filter at the local ford dealer.
Old Apr 21, 2010 | 03:18 PM
bpounds's Avatar
bpounds
It should be checked while HOT, engine running, in Park or Neutral. And it needs to be good and hot, so the fluid is hot enough to open the path to the external cooler.
Totally different tranny, just for the record.
Old Apr 21, 2010 | 03:37 PM
rickf92592's Avatar
rickf92592
FYI, you really don't need to drop the pan (at least on my '05), that filter's a trash filter and if it needs replaced they'll do it when they rebuild the tranny; if you know what I mean. Mine takes a little over 7 when I drain it from the plug.
+1 on the check while hot.
Old Apr 21, 2010 | 06:52 PM
WestxSRT10's Avatar
WestxSRT10
Mine took just over 9.5 qt after i dropped the pan but i have the internal filter only.
Old Apr 21, 2010 | 08:39 PM
Tom's Avatar
Tom
My shop manual says 7.5 quarts.
ugh3012
Mar 8, 2016 10:45 PM
f250mtnbikr
May 5, 2015 08:58 AM
FordLou
1997 - 2003 F150
13
Dec 10, 2014 09:36 PM
johnsjsj
Apr 16, 2014 07:16 PM
adam10
Mar 15, 2014 08:06 PM
