Sponsored by: Auxito
Wiper Blade Chatter
Old Jan 29, 2003 | 04:24 AM
valleyflyer's Avatar
valleyflyer
Wiper Blade Chatter
Hey,
My first posting and looking for suggestions for windshield wiper chatter.
I would usually replace the blades about every month before the chatter would start up again and then recently the chatter started soon after blade replacement. I installed new Anco blades and when the chatter started up I replaced the arms and even had the tension checked. I keep my glass clean but still continue to get a loud and irritating chatter when they swipe through the upper end of the windshield. I hate to put coatings on the glass but maybe that is the last resort or maybe there is a "miracle" blade that works great. Just looking for ideas.
Thank-you!
Jeff
(1997 F150 Flareside Lariet 4X2/5.4, 58,000 miles, owned for 3 years and no big problems - Great Truck!)
Old Jan 29, 2003 | 05:40 AM
Bob Ayers's Avatar
Bob Ayers
Wiper Blade Chatter
Make sure the wiper blades are sitting perpendicular to the
windshield. If they are sitting at an angle (other than 90
degrees), then they will chatter when swiping in one direction. You can adjust the angle they sit at by bending
the arm....good luck!!
Old Jan 29, 2003 | 06:29 AM
Torque1st's Avatar
Torque1st
Posting Legend
Wiper Blade Chatter
Bob is correct. I usually use a "crescent" wrench or "adjustable end wrench" to grasp the flat portion of the arm and give it a "tweak".
Rain-X is a VERY good product that when applied properly will take you thru the absolute worst downpour, with semi's on every side, with your wipers turned off, and having perfect vision! It is absolutely amazing! WONDERFUL stuff!!!
In fact if you use the wipers it disturbs the coating and it does not last as long.
There are some newer products that are supposedly easier to apply but I have not tried them. -Yet!
Old Jan 31, 2003 | 03:25 AM
valleyflyer
Wiper Blade Chatter
Bob, it sounds like a good idea but can you clear me up a bit on what you mean with the angles and the position of the blade/arm.
Thanks
Old Jan 31, 2003 | 05:10 AM
Bob Ayers's Avatar
Bob Ayers
Wiper Blade Chatter
Hi Valleyflyer,
If you send me your e-mail address (rlayers@us.ibm.com),
I'll do a diagram and e-mail it to you...
Bob
Old Feb 4, 2003 | 02:56 PM
pilot10's Avatar
pilot10
Wiper Blade Chatter
I've heard the wax from the drive-thru car washes can cause wiper chatter.
Try rain-x (don't forget the side windows). I've been using since the early eighties and it is a product that works as advertised(if not better).
Tim
PS- Rain-x also has entertainment value as you don't often get to see water run uphill.
mtntop1
Aftermarket Products
13
Feb 17, 2015 09:57 AM
Sputz
2009 - 2014 F150
Aug 26, 2014 12:09 AM
CDN Ford 4x4
1997 - 2003 F150
Dec 25, 2009 02:26 PM
Rikster-7700
2004 - 2008 F150
27
Jun 12, 2009 04:05 PM
Animalistic
Apr 7, 2008 08:49 PM
