Drivers Door Lock Cylinder
Old Apr 20, 2010 | 12:54 PM
03-6L-X's Avatar
03-6L-X
My drivers door key lock cylinder has become loose and if you play with it you can get it to start to come out.
Is there a way to get it to stay?
Looked at it to see if there was anything there but did not see anything. Have not looked at the passenger side to see how it looks to compare the two.
Old Apr 20, 2010 | 01:14 PM
daveengelson's Avatar
daveengelson
Suggest check and see if the door lock retainer clip is secure, should look simular to pic, may find it rattling around in the bottom of the door.
http://www.parts123.com/parts123/yb....4g~Z5Z5Z510588
Old Apr 20, 2010 | 05:16 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
If it fell off, it's prolly history, has given up the ghost. You can re-install it...but how long it will stay in place?
C4AZ6222023A .. Door Lock Cylinder Retaining Clip / R/L is the same / Obsolete
Fits: 1964/66 F100/1100 / 1960/64 Galaxie / 1962/65 Fairlane / 1965/66 Mustang / 1966/77 Bronco.
DON SANDERSON FORD in Glendale AZ has 12 = 623-842-8762.
GREEN SALES CO. in Cincinnati OH has 22 = 800-543-4959.
Old Apr 20, 2010 | 05:31 PM
03-6L-X's Avatar
03-6L-X
Found it and put it back. Have the U facing down rather than up. Will get new ones, just to be safe.
Thank you both for the help.
Old Apr 21, 2010 | 11:03 AM
03-6L-X's Avatar
03-6L-X
Ment to start new thread, sorry.
Old Apr 21, 2010 | 11:13 AM
NumberDummy
Originally Posted by 03-6L-X
1) Weather stripping for inside the door window tracks and inside and outside door.
Reproduced, Carpenter makes the best stuff.
2) Have tried a couple of aftermarket Coolant Temp probes and cannot get the temp gauge to get past the first line on the left. Is there anyway to get a FoMoCo original?
Do you want the temp gauge or the sending unit?
3) Wiper assembly. Wipers work (two speed), just that the drivers side wiper slaps the weather stripping everytime at the bottom of the stroke.
There is no wiper assembly, just individual parts. You may need a new wiper pivot, or just...re-position the wiper arm on the pivot.
4) Rubber outside of cab for fuel tube and rubber from fuel tube to gas tank.
What do you mean by rubber? The neoprene fuel lines? Any autoparts store will have it.
Are you also asking for the rubber grommet that fits around the filler neck, outside the cab?
Old Apr 21, 2010 | 11:59 AM
03-6L-X's Avatar
03-6L-X
The Rubber hose that connects the filler neck to the gas tank.
Yes the rubber grommet.
Bill moved your answer to 66 F250 Need Parts Thread, thank you for your help.
hilljj
Jun 5, 2014 01:48 PM
Doraville
30
May 11, 2013 03:02 AM
F1Newb
18
Oct 6, 2011 12:53 AM
cchildress
Jul 30, 2008 02:54 PM
jjs2032
Apr 22, 2008 08:27 AM
