rocker studs
Old Apr 20, 2010 | 10:55 AM
sid318's Avatar
sid318
rocker studs
Hi guys anyone have had arp rocker studs snap, had 2 snap now engine not even done 10 miles yet, any ideas to problem other than faulty studs ? Kev UK.
Old Apr 20, 2010 | 03:08 PM
bashby's Avatar
bashby
sounds like the rocker is binding up for some reason.
Old Apr 20, 2010 | 04:42 PM
1bad67sbf's Avatar
1bad67sbf
are your valve springs matched to your cam
Old Apr 20, 2010 | 04:59 PM
lew52's Avatar
lew52
I think you have another problem ARP studs won't fail in 10 miles , there very good ....Lew
Old Apr 20, 2010 | 05:12 PM
1bad67sbf's Avatar
1bad67sbf
where did they snap (flush with head or up at the rocker) i would have thought a push rod or rocker arm would break before a stud. i have been told to use 7/16 studs if i can from two machine shops due to them having repaired broken 3/8 studs many times on high performance sbf motors.
Old Apr 20, 2010 | 05:27 PM
Conanski's Avatar
Conanski
Makes me wonder.. are these real ARP studs or just cheap Chinese copies. I don't think you could break a real APR stud.. something else would give first like the rocker or the head itself. Where did you get these studs from anyway? Lets hope it wasn't Ebay.
Old Apr 22, 2010 | 12:08 AM
Beanscoot's Avatar
Beanscoot
They could have broken due to not being tightened sufficiently. Check out the ARP website, it's very informative and they describe various kinds of failures (six as I recall).
Old Apr 25, 2010 | 08:20 AM
sid318's Avatar
sid318
Hi guys hopefully problem sorted contacted world products [roush iron heads fitted] apparently studs to short only 5-6 threads going into locker so need slightly longer studs ! they say don't need 7/16th studs unless going over 600 lift have 540 , only time will tell ,cheers for replies, Kev UK.
Blackwaterforge
Aug 20, 2010 09:20 AM
CommrclDiver
19
Feb 17, 2007 09:23 AM
Fuzydog
Garage & Workshop
Dec 7, 2006 05:55 PM
hoxiii
Nov 14, 2005 02:51 PM
chrowen
Jun 2, 2004 10:15 PM
