need some help!?
Old Apr 19, 2010 | 11:17 PM
crowbar_96854's Avatar
crowbar_96854
need some help!?
ok, Ive got a 97 f-250hd. 250000 plus miles. I have to turn it over at least 3 times before it starts to begin with. after it starts it lopes like a dragster for about a min. when I first take off its real weak and then takes off like a rocket. going down the highway at a maintained throttle it surges sometimes and I have an awful oil leak coming from the top of the engine somewhere. anybody have an idea where I should start??
Old Apr 19, 2010 | 11:58 PM
JamesHajek's Avatar
JamesHajek
First thing i would do is check the HPOP res and make sure its at least 1/2 from the top. Next is find out where that leak is coming from. If its coming from the HPOP itself or maybe a knick in the lines. I haven't had this problem, so im just guessing, maybe somebody else will chime in.
Old Apr 20, 2010 | 03:48 PM
fordpride's Avatar
fordpride
is your hard start all the time or just after it's been sitting for 6 hours or more
Old Apr 20, 2010 | 07:13 PM
FARM69's Avatar
FARM69
The oil can either be coming from the turbo pedestal or the EBPV. Most likely the o-rings out on the pesdestal.
As far as the romping, when is the last time you changed your oil and fuel filter?
Old Apr 20, 2010 | 10:47 PM
crowbar_96854
the hard to start is only its been sitting overnight. I live in Texas so it hasnt been getting cold. as for the oil and fuel filter change its been less than 300 miles. it just started kind of suddenly, I try to keep my engine fairly clean but I cant tell where the oil is coming from. It starts somewhere around the middle of the engine and goes back. It only leaks when I drive it.
Old Apr 21, 2010 | 06:10 AM
FARM69's Avatar
FARM69
Sounds like the hpop is draining on you.
Old Apr 21, 2010 | 05:15 PM
fordpride's Avatar
fordpride
next time it sits over night check HPOP reservoir and see if it's low it should be atleast 1/4" from the threads
prikleepear
Sep 22, 2013 05:43 PM
574_ford
Nov 16, 2011 04:50 PM
matconger
Jun 22, 2010 09:28 AM
YungHotRod9090
17
Oct 4, 2006 12:48 PM
Mykro
Aug 30, 2003 01:17 PM
