Rubbing/grinding sound under load
Old Apr 19, 2010 | 07:40 PM
YooperJack's Avatar
YooperJack
Hi All,
Just bought a 2000 Expy a month ago, though I am certainly no stranger to Fords. It is a 4x4 with the 5.4 motor, 3.55 gears and 118K miles.
I hear a rubbing/grinding sound when going slowly (20mph) up a rather steep hill near my house. It is not steady, but oscillates almost as if it is with the wheel rotation. It feels as if it is coming from right under my feet.
I also feel the same rubbing/grinding sensation at freeway speeds when throttling up a hill to hold my speed.
The sensation goes away in both situations when I the off the throttle. And it does it in 2wd mode. I confess that it didn't occur to me to test it in 4wd mode until just now.
Any experience/advice with this noise? Thanks to all.
Jack
Hangtown, CA
Old Apr 19, 2010 | 07:56 PM
madsonp's Avatar
madsonp
I believe the front drive shaft is located very close to other components. You might take a look under there to see if you can see any signs of rubbing.
Old Apr 19, 2010 | 08:08 PM
YooperJack's Avatar
YooperJack
Front shaft rubbing?
Does the front shaft turn even when in 2wd?
Thanks for your reply, BTW.
Old Apr 19, 2010 | 08:24 PM
madsonp's Avatar
madsonp
I believe so, if I remember correctly.
Old Apr 19, 2010 | 09:26 PM
pdqford's Avatar
pdqford
I didn't think the 2000 had a selector position for 2WD. Does it?
Old Apr 20, 2010 | 01:32 AM
YooperJack's Avatar
YooperJack
2000 Explorer 4wd
It has a **** on the dash that says AWD/4Hi/4Lo, so yeah I assumed incorrectly it was a 2wd setting. The AWD then, is a computer-controlled 2wd/AWD situation???
What I don't get about it, with respect to my earlier question about the drive shaft turning is that I can definitely tell the difference between the AWD and the 4wd setting. So I assumed the driveshaft was not engaged in the AWD mode.
Anyway, I will check for driveshaft clearances.
Old Apr 20, 2010 | 12:02 PM
pdqford's Avatar
pdqford
It has a **** on the dash that says AWD/4Hi/4Lo, so yeah I assumed incorrectly it was a 2wd setting. The AWD then, is a computer-controlled 2wd/AWD situation??? .
The front DS always turns with the front wheels. (In other words, there is no "lock-out" on the front hubs.)
When in 4WD the transfer case clutch is engaged and the front and rear DSs try to turn together. (That's what causes the drive train to 'bind up' if you try to turn on a hard surface. )
When in AWD (All Wheel Drive) the transfer case clutch is disengaged (which allows you to turn easily on hard surfaces), until the computer detects that the front and rear driveshafts are turning at different speeds. The computer then engages the transfer case clutch which locks the front and rear driveshafts together.
Old Apr 20, 2010 | 05:34 PM
madsonp's Avatar
madsonp
I thought that was how it worked but I couldn't remember for sure (it's an age thing you know), thanks for setting us straight and clarifying it for us.
Old Apr 21, 2010 | 02:11 PM
pdqford's Avatar
pdqford
I can relate to that!
Old Apr 21, 2010 | 09:31 PM
alloro's Avatar
alloro
Eh, what was that you said?
Old Apr 22, 2010 | 02:17 PM
ArgoExpedition's Avatar
ArgoExpedition
I had a similar problem with my 1999 f150, ended up being the rear axles were worn out. So much so they had to use a crow bar and force the axles past the warn part where the bearings wore a 1/8 " groove.
I cannot say for sure that would be your problem, but a 6000 ish GVW on my f150 and carrying it at 5500 lbs for only 75,000 miles really burned me on buying another f150. Especially when the dealer mechanic told me that the rear axle was the same as the Mustang axle.
blwn350
Mar 2, 2017 11:50 AM
97-psd
Jul 22, 2016 05:59 AM
dh_meyer
2009 - 2014 F150
Nov 4, 2015 09:32 AM
Davis5149
1997 - 2003 F150
Jun 10, 2015 05:47 PM
SD Dually
May 21, 2014 12:39 PM
