2001 Explorer rear end?
Old Apr 19, 2010 | 03:21 PM
My Ford Truck's Avatar
My Ford Truck
My '55 truck build has been put on hold due to some unfortunate housing expenses like repairs to two foundation walls, termites (just showed up so no damage), a broken kitchen drain pipe (have to repair from the outside or demo the kitchen), and four replacement windows.
However I have a chance to pick up a 2001 Explorer rear end, supposedly with under 30K miles, for $100. Explorer was hit in front and is being parted.
Good choice/bad choice? Problems with putting this 2001 under my '55?
Anything else I need to look for? I might pick up the 4 tires/rims if priced right.
Thanks in advance!
Jeff
Old Apr 19, 2010 | 03:32 PM
jaye's Avatar
jaye
I have one under my 55 its from a 94; you will probably have disc brakes on the 2001 the width should be the same; I would also get the drive shaft. I would say get it if you have the extra funds they are a lot more a pull-a-part yards.
Old Apr 19, 2010 | 06:09 PM
49fordpickumup's Avatar
49fordpickumup
Did they have anti-skid by then? I don't know if that will affect anything. Might google and read up on the rearend. chuck
Old Apr 19, 2010 | 10:28 PM
SunDown's Avatar
SunDown
I'm sure the explorer had some sort of ABS in 01 but it shouldn't concern you ont he rear axle. ABS is controlled by a brake module that is plumbed just short of the master cylinder. Wouldn't be an issue on a axle swap like you're talking
Old Apr 19, 2010 | 10:57 PM
tip49's Avatar
tip49
Have a 2001 Explorer rear end in my '50; no issues. I'll be looking for 3 1/2" backspace to clear box with enough clearance.
Old Apr 20, 2010 | 08:16 AM
TxF100's Avatar
TxF100
I have a '96 in my 55 and they should be the same. The width is just about the same and the disk breaks are a plus. Around the Houston area they go for $300 for a good low mileage dif. You will want to be sure to pick up the drive shaft as well as the parking break cables and all the brackets if you can.
xgkrx
Apr 25, 2015 07:34 PM
U235Fishin'
6.7L Power Stroke Diesel
25
Jan 5, 2015 05:42 PM
sunuvabug
Ontario Chapter
Nov 26, 2014 09:02 AM
jcstarr
1983 - 2012 Ranger & B-Series
Jan 9, 2007 06:21 PM
jscozz
Nov 8, 2006 01:49 PM
