Cab mounting ?
Old Apr 19, 2010 | 09:16 AM
terryb4471's Avatar
terryb4471
Cab mounting ?
I'm getting ready to mount the cab back on. The rear mount brackets, which whey do they mount . I'm using the stock brackets. Is it the straight side toward the frame or the side that has the two ends angled.
Thanks
Old Apr 19, 2010 | 09:57 AM
Old F1's Avatar
Old F1
So I see by your profile that your truck is a 1950? I think they where used from 48-56. Do you mean the “arm” part of the mount, the new ones are kina’ a dog bone thing, here is some old rusty ones for ya!
Old Apr 19, 2010 | 01:39 PM
terryb4471's Avatar
terryb4471
Sorry its a 1950. Its the first picture. Does the side that has the cut out or angle in the bracket mount against the frame and rubber.
Old Apr 19, 2010 | 02:15 PM
jmadsen's Avatar
jmadsen
the angled portion of mount faces outward or down, away from cab and frame.
(straight side towards frame as you put it.)
Cheers
Josh
Old Apr 19, 2010 | 03:03 PM
Old F1's Avatar
Old F1
The first picture show where the rubber block goes. Now I took these so that I would know how to put it back together and the cab was (and is) sitting on its back, so everything is upside down and a$$ backwards but if that swings out to bolt to the frame would not the top of the arm be the piece with the cut off corners? I hope so because that is the way it looks to me but it has been two weeks and the old memory just isn’t what it used to be!
Old Apr 19, 2010 | 04:19 PM
jmadsen's Avatar
jmadsen
that picture got me all turned around too could be that someone got them in backwords, but maybe it really does not matter the direction? I just went out and looked at one of the trucks in the driveway so maybe I'll look at the others to see if they are the same too. ?
Josh
Old Apr 19, 2010 | 04:27 PM
terryb4471's Avatar
terryb4471
Thanks for the help. I'm picking the cab up tonight and looking to have it mounted this weeked.
57bob
Feb 4, 2014 08:17 PM
markb3529
May 6, 2010 03:49 PM
Steve Bennett
Feb 26, 2009 06:52 AM
389sixpack
May 29, 2007 01:30 PM
289freak
Aug 11, 2001 12:31 PM
