Parking Brake Bracket
Old May 5, 2010 | 09:07 AM
markb3529's Avatar
markb3529
The bracket that is attached to the frame where the two ends of the rear parking brake cables are held in place has rotted through. The bracket is mounted on the side of the frame rail just behind the cab. I'm not sure that this is common, but was wondering if anyone knows if there are new replacements available or if I should just call some junkyards or just try to make a new bracket. What do you guys think? Thanks!
Old May 5, 2010 | 09:31 AM
Neal 97 250's Avatar
Neal 97 250
Try making one if you have the capabilities. Or try a junkyard. Or you can get most anything from Parts Guy Ed. He is a sponsor here on FTE and sells OEM parts.
Old May 5, 2010 | 08:34 PM
Mdt1992's Avatar
Mdt1992
those things are all over the junkyards around here, i believe they are the same for all the f-series trucks
Old May 6, 2010 | 03:49 PM
crazy4wdracer's Avatar
crazy4wdracer
Mine rusted alot and ended up snapping plus there was really no adjustment on mine (yours might be different). What I did is take 2 pieces of stainless sheeting and bolted them together, it works great except my rear cables are froze up. I'll try and take a picture later to show you.
johnmel59
Dec 11, 2014 02:55 AM
84espy
Mar 28, 2014 07:10 PM
markkay4356
1978 - 1996 Big Bronco
Nov 20, 2013 03:25 PM
thunderbirdcakes
Sep 12, 2013 05:48 PM
