Did I mess up?
Old Apr 21, 2010 | 01:36 PM
69cj's Avatar
69cj
If you have concerns, place an earth magnet on the outside bottom of the carrier. Any metal debris going by it will be stuck there and you will see what's actually hapening in a few thousand miles. It also keeps the leftover crap from circulating in the new oil.
Old Apr 21, 2010 | 04:10 PM
06yz125's Avatar
06yz125
Great idea.
Probably a dumb question but I'm used to asking those...
Whats an "earth" magnet?
Old Apr 21, 2010 | 04:34 PM
rocky1074's Avatar
rocky1074
I would think it's a magnet we use here on earth..lol
Old Apr 21, 2010 | 04:38 PM
bismic's Avatar
bismic
Originally Posted by 06yz125
Great idea.
"Rare Earth" magnet is the terminology. They are some of the strongest magnets you can get. They are made from alloys of "rare earth" elements (like neodymium, samariu-cobalt, etc).
Old Apr 21, 2010 | 04:45 PM
origcharger's Avatar
origcharger
Suddenly the melody of "I Just Want To Celebrate" is going through my mind.
Old Apr 21, 2010 | 05:09 PM
rocky1074's Avatar
rocky1074
Mark If I had yourKnowledge I would throw mine away.
lol
Old Apr 21, 2010 | 05:29 PM
06yz125's Avatar
06yz125
Now for my next question...do earth magnets wear out?
Just kidding..you don't have to answer that but I'm sure someone will.
Have we gone far enough off the subject yet. LOLOL HEHEHE
Old Apr 21, 2010 | 06:25 PM
bismic's Avatar
bismic
Kind of interetsing story .................
I used to work at a manufacturing site for Pharmaceuticals. We handled large volumes of Hydrofluoric acid, Phenol, Carbon Monoxide at VERY high pressures .............. and the most common accident was hands getting seriously pinched by the rare earth magnets (used to keep metal out of the final product). They were amazing (but they were big also). From what I observed, they did not lose their strength in the 4 years I was involved with them.
69cj's recommendation was a good one IMO. Good luck to you (and sorry about the hijack .........)
Old Apr 21, 2010 | 06:30 PM
69cj's Avatar
69cj
You can buy them approximately 3/8 inch dia. cheap at Harbor Freight. You almost need a pair of pliers to pull one off.
Old Apr 21, 2010 | 06:37 PM
npccpartsman's Avatar
npccpartsman
HAHAHAHAHA---I love youtube. My sis has the ORIGINAL version album in vinyl from WTFB in the day. Talking about bring back some hallucinations...........uhhhhh memories.
Old Apr 21, 2010 | 06:39 PM
npccpartsman
Great idea.
There are no "dumb" questions. Only questions that are simpler to answer than others.
Old May 10, 2010 | 06:03 PM
JDTDBD's Avatar
JDTDBD
I dropped my 04 f250 with LS off at a local mechanic and he added Valvoline 75/90 synthetic that states,"SynPower Gear Oil is specially recommended for limited-slip hypoid differentials" and "Reduces Chattering: Contains special additives to reduce chattering in limited-slip differentials" and "Valvoline SynPower Gear Oil is recommended for use in axle applications requiring factory-fill or drain-and-fill levels of limited slip performance." I talked to the mechanic once i saw the bill and the gear oil he used and he told me not to worry. He also didnt change the front cause he said it looked new, and only changed the rear. So I feel like he isn't out to screw me and take my money. Any thoughts?
Old May 10, 2010 | 06:07 PM
  #28
cartmanea's Avatar
cartmanea
It will probably be okay as long as you don't do much racing or towing. If you tow at all though, I would get the proper weight fluid in there.
Old May 10, 2010 | 06:17 PM
  #29
gearloose1's Avatar
gearloose1
Short answer: Yes.
Longer answer:
Rare earth magnets have higher remanence, much higher coercivity and energy product, but (for neodymium) lower Curie temperature than other types. The table below compares the magnetic performance of the two types of rare earth magnet, neodymium (Nd<sub>2</sub>Fe<sub>14</sub>B) and samarium-cobalt (SmCo<sub>5</sub>), with other types of permanent magnets. <table class="wikitable" border="1"><tbody><tr> <th>Magnet</th> <th>B<sub>r</sub> (T)</th> <th>H<sub>ci</sub> (kA/m)</th> <th>(BH)<sub>max</sub> (kJ/m<sup>3</sup>)</th> <th>T<sub>c</sub> (°C)</th> </tr> <tr> <td>Nd<sub>2</sub>Fe<sub>14</sub>B (sintered)</td> <td>1.0–1.4</td> <td>750–2000</td> <td>200–440</td> <td>310–400</td> </tr> <tr> <td>Nd<sub>2</sub>Fe<sub>14</sub>B (bonded)</td> <td>0.6–0.7</td> <td>600–1200</td> <td>60–100</td> <td>310–400</td> </tr> <tr> <td>SmCo<sub>5</sub> (sintered)</td> <td>0.8–1.1</td> <td>600–2000</td> <td>120–200</td> <td>720</td> </tr> <tr> <td>Sm(Co,Fe,Cu,Zr)<sub>7</sub> (sintered)</td> <td>0.9–1.15</td> <td>450–1300</td> <td>150–240</td> <td>800</td> </tr> <tr> <td>Alnico (sintered)</td> <td>0.6–1.4</td> <td>275</td> <td>10–88</td> <td>700–860</td> </tr> <tr> <td>Sr-ferrite (sintered)</td> <td>0.2–0.4</td> <td>100–300</td> <td>10–40</td> <td>450</td></tr></tbody></table>
Rare-earth magnet - Wikipedia, the free encyclopedia
Rare earth magnets like Nd<sub>2</sub>Fe<sub>14</sub>B start to fade out at 300C, but the cheap kinds you get at Harbor Freight probably fade out a lot sooner.
So it is not that it "wears" as much as heat damages them.
Attached to an oil sump, that is not a big problem (your oil will boil before the magnets die), but in electric motors, temperature is a major issue.
That is why electric vehicles have a lot more hurdles than most advocates let on.
Old May 10, 2010 | 06:30 PM
  #30
cartmanea's Avatar
cartmanea
Except a lot of the hybrid electric traction motors are induction and not permanent magnet.
