Intake temp results
Old Apr 18, 2010 | 03:03 AM
Sycostang67's Avatar
Sycostang67
Post Intake temp results
I thought I would share this with you guys as well. I put a temperature probe in my filter box and tested 3 different intakes to see what kind of incoming air temps I was getting. I tested my hypermax kit, the factory tube that sits on the core support, and no tube at all. I had the truck nice and warmed up before testing and drove the same route/distance with each setup. I made sure the weather was clear with no wind/rain etc.. Here are my results.
Outside temperature was 72*
Hypermax Cowl induction:
60mph cruise-80*
2 minute idle-105*
Factory intake:
60mph cruise-82*
2 minute idle-126*
No tube:
60mph cruise-125*
2 minute idle-140*
The factory tube absorbs heat rather quickly at idle, it had reached 110* within the first minute of idling, while the others gradually climbed in temp. The hypermax kit also drops the temp much quicker when you start moving.
Old Apr 18, 2010 | 07:56 AM
93_F250's Avatar
93_F250
Thanks for the post and the data. I removed the factory snorkel from the core support and just left the 4" tube open in the engine bay connected to the Banks filter kit.
I plan to open up a 4" hole at the front of the core support and run a 4" duct from the front grill. Your data supports this as a worthwile mod. It also looks like some sort of insulated (or thicker) 4" tubing might also be worthwile.
What type of temp probe did you use? I would like to know my post turbo intake temps. I have a IAT gauge I use to monitor on my S/C gasser and thought about placing the sensor where I tap into the boost gauge (1/4 NPT) to see if some type of intercooler would offer any real gains.
Old Apr 18, 2010 | 09:56 AM
fuzzy1626's Avatar
fuzzy1626
Great info. Thanks
genscripter
23
Apr 12, 2016 01:30 PM
Bread
60
Sep 18, 2014 12:03 PM
motocamper
Dec 23, 2012 08:55 AM
FFemt5287
Jan 2, 2009 12:42 PM
