Is it still touching the high idle solenoid???
That solenoid is adjustable ... The brass stem part that actually touches the throttle lever screws in (or out) to adjust the high idle. It may be out to far.
I personally have never pulled a db2 apart, never had one I really didn't care about.
Yep, it's still touching the solenoid. I'll try adjusting it. I figured since the bracket had some adjustment room that the solenoid wasn't adjustable. That's what I get for assuming.
