View Poll Results: What material would you prefer for your fuel return caps?
Stainless Steel
28.57%
Aluminum
35.71%
Brass
28.57%
Plastic
7.14%
Other (state your material choice)
0%
Voters: 14. You may not vote on this poll
Return line caps...
Old Apr 29, 2010 | 10:33 PM
  #31
FORDF250HDXLT's Avatar
FORDF250HDXLT
wow cool.any idea's on price, for a set of 8 yet?
Old Apr 29, 2010 | 10:53 PM
  #32
Marianna2003's Avatar
Marianna2003
I really hate to say this, but I think that injector is for a 6.2 GM diesel joke. I'd rather put up with the leaking return lines than that motor!
Old Apr 29, 2010 | 11:03 PM
  #33
rodneywar's Avatar
rodneywar
if they built an injector with a intergral return that is made just for the 7.3 idi. would you buy them then?
Old Apr 29, 2010 | 11:20 PM
  #34
PSD97's Avatar
PSD97
Come on man, that design per se has absolutely nothing to do with a 6.2. Like I said, most, maybe all, serious big OTR and off road diesels alike from International and others had that type injectors. I'd buy a set ASAP if they were available, 'cause i need new ones now.
Old Apr 30, 2010 | 02:36 AM
  #35
tecgod13's Avatar
tecgod13
Unless I'm mistaken, thats a Bosch injector for a 1.5 or 1.6L Volkswagen engine. They were used in the (original) Rabbits, Jettas, VW pickup and I think Vanagons. Similar engine was used in the Quantums too I think?
Its a nice system, just link from injector to injector, block off one end, the other end goes to the outlet banjo bolt fitting on the injection pump, then back to then tank. A lot easier than the pain in the rear plastic cap solution. One problem though, they do make the injector wider and harder to put a socket on.
Old Apr 30, 2010 | 06:56 AM
  #36
mechelement's Avatar
mechelement
I want to see the finished project and know the man hours to complete a set.
Anyone know how hot those injectors get?
With brass or aluminum, he's going to drill and tap thru-holes for hose barbs and make the barbs are 1/4" longer than the stock plastic barbs. He said that they'll need to be brazed or TIG welded on depending on what material. He mentioned using an old injector to hold the caps in place while brazing / welding. He said he wants to think about the material a little more. He's like a kid in a candy store when I give him stuff like this.
Old Apr 30, 2010 | 11:36 AM
  #37
PSD97's Avatar
PSD97
The temps are easy to check with an infrared gun, but the weather is not hot enough and i don't haul big loads so i can't come up with a worst case scenario, which is what you'd probably want.
This may be a little off topic, but I was wondering if there is some reason one couldn't tap the hole on the injector and put a barb there? All it has is a single hole. The rest of the return line would consist of T's and a "main line". This would at least eliminate the o-rings completely. Just a thought.
Old Apr 30, 2010 | 11:50 AM
  #38
rodneywar's Avatar
rodneywar
nota bad idea actually
Old Apr 30, 2010 | 06:39 PM
  #39
mechelement
Good idea. I'm sending that picture to my dad so he knows what that setup looks like.
Old May 1, 2010 | 01:43 PM
  #40
Marianna2003
The body is probably hardened. You could solder a tube in there. Too bad IH didn't do that. I guess they never figured on diehards like us running them long enough to become a problem. As far as temperature is concerned, I think Viton can handle higher temps as well as tolerate Biodiesel. It may be the ULSD that's causing our woes.
Old May 1, 2010 | 03:49 PM
  #41
PSD97's Avatar
PSD97
The body is actually real soft, I tried with a drill. The problem is that the barb can end up pointing any which way when the injector is torqued down to spec. I can see at least four ways to deal with that:
(1) using different thickess copper washer at the bottom a la Caterpillar. I don't know if that small a change in installed depth would affect how the spray goes into the prechamber, maybe, maybe not.
(2) A long enough hose going to the mainline so that it can make a turn even from the "wrong side" of the injector,
(3) A 90 degree turn in the return hose right at the barb, hose points up and the mainline is running right above the injectors. That way it shouldn't matter too much which way the barb points,
(4) never mind the torque spec and turn the injector until the barb points where it needs to point.
(5)some combination of the above
But anyway, the metal caps would likely be a pretty good, long term solution. I'm looking forward to seeing a prototype and some price estimates from mechelement.
Old May 2, 2010 | 11:37 AM
  #42
Marianna2003
I didn't mean I don't like that injector. I like the idea of integral outlet tubes. It wouldn't take much to have them added to our injectors when they are being manufactured. Fat chance of something like that happening.
Sincerely,
Gene O
Old May 2, 2010 | 02:14 PM
  #43
mechelement
This morning I bought a -58 to +1000 degree high temperature infrared thermometer at Sears. I ran the truck normal home and measured the temperature of the bottom of the injector. They were around 194 degrees.
My dad called and said the brass stock he wants to use is $40 per linear foot vs the $9 per linear foot aluminum. It looks like this round he's going with aluminum for the caps.
alchemist1
16
Jul 20, 2012 01:03 PM
lnthecurly
13
Aug 10, 2011 09:01 PM
LFDavidson
23
Nov 6, 2010 01:14 PM
Smiley1
Nov 25, 2009 09:55 AM
deyomatic
Dec 17, 2008 07:52 PM
