Installing bigger fuel lines
Old Aug 4, 2011 | 11:03 AM
lnthecurly's Avatar
lnthecurly
I'm upgrading my system to 3/8" fuel lines. Is is possible to get injector caps, and hose barbs for the IP and filter in this size?
Old Aug 4, 2011 | 03:32 PM
Marianna2003's Avatar
Marianna2003
WHY? even at 10 mpg, you're only ngoing to burn 6 gallons per hour at 60MPH. Doing that would be like wetting yourself in a dark suit! It gives you a warm feeling,but nobody will notice.
Old Aug 5, 2011 | 12:03 AM
starmilt's Avatar
starmilt
Hose barbs would b no problem.
The injector caps would have to be custom machined and SPENDY for no advantage that I could see at all.
If it changed the performance at all, it would be for the worse. We used ti pinch the return line on the old cummins to make them go, when you had about a foot of flame out of the stack, you had it pinched about right.
Old Aug 5, 2011 | 09:12 PM
ford390gashog's Avatar
ford390gashog
WHY????????????? The stock fuel system provides more fuel then the IDI will ever need!! Even with a all out moose pump!!
Old Aug 6, 2011 | 12:15 AM
hairyboxnoogle's Avatar
hairyboxnoogle
It is believed that the moose pump and injectors can be pushed further with larger lines. Currently the big moose injectors are bored to the diameter of the lines, bigger lines would allow the injector to be bored even more, allowing even more fuel. This is something im interested in as well. I wonder if you could take the caps off our lines and simply bore them to the OD of the larger lines... its late and im tired so im assuming im not thinking properly, that sounds way too easy.
Old Aug 6, 2011 | 06:43 AM
84-6.9L's Avatar
84-6.9L
There are larger lines out there. We use them for tractor pulling all the time, they are not 3/8". They are only slightly larger, even superstock tractors running boost over 100 psi with 4 turbos IIRC are only in the neigborhood of 1/4"
Old Aug 9, 2011 | 04:52 PM
Marianna2003
If you're thinking about increasing the size of the high pressure line running between the IP & Injectors, you'll have to be looking for some serious HP before the lines become the critical point.
Old Aug 10, 2011 | 12:00 AM
FORDF250HDXLT's Avatar
FORDF250HDXLT
she can only burn so much oil at a time.you can already roll coal by turning up the fuel,which goes unburnt out the tailpipe and gets too high EGT's as is.even with turbocharged engine.
besides that,imagine if you could somehow convert the thing to direct injection (just for starters i mean as IDI isn't possible) so it burnt enough fuel to require such a large size........you wouldn't be measuring fuel economy in miles anymore.
but i think your interested in just increasing the return lines.....still,why? is a good question.
Old Aug 10, 2011 | 02:48 AM
lnthecurly's Avatar
lnthecurly
why?
...because a couple of people who have done it advised me to so, I suppose based upon the oil being thicker. However it seems a lot of users on here don't think it is necessary. I think I'll just try the conversion without larger fuel lines and see if it works.
lnthecurly's Avatar
lnthecurly
clarification
i'm converting the truck to run on recycled vegetable oil
Old Aug 10, 2011 | 08:18 AM
84-6.9L's Avatar
84-6.9L
But the BTU's in the oil should mean you need to use less fuel.
Old Aug 10, 2011 | 01:39 PM
Marianna2003
You just naeed to heat the Veggy oil to reduce its viscosity so it can be pumped without any problems.
Old Aug 10, 2011 | 08:41 PM
kenpobuck's Avatar
kenpobuck
I second that! Not heating the oil is a bad thing. It will cause coking and cause exsessive wear of all the parts used to pump it.
Old Aug 10, 2011 | 09:01 PM
ihateminimumwage's Avatar
ihateminimumwage
Not to mention molding up. Veggie oil, fryer grease, etc. needs to be heated, or you're going to have some big issues.
lnthecurly
Bio-diesel, Propane & Alternative Diesel Engine Fuels
Aug 6, 2011 02:46 PM
rlwilson2
22
Jun 20, 2010 08:22 AM
uchitz
May 16, 2008 05:48 AM
firebug
Feb 20, 2008 01:07 PM
dnroberts
Nov 27, 2007 07:28 PM
