On again, off again starting issue
Old Apr 18, 2010 | 04:22 PM
skinnyman94's Avatar
skinnyman94
we coulddo that yesterday. but when we let it sit while we cleaned up and put tools away and showered. went to leave and nohitng. and couldn't get it to start by moving gear shift selector
Old Apr 18, 2010 | 05:17 PM
Beeler's Avatar
Beeler
Okay, it appears that my issue was the starter solenoid. After getting the wrong one from parts store, I installed a new one and the truck fired right up. I did clean all my cable ends, including the ground ends. Put two new ends on two of the cables. Auto Zone was able to get me a soleniod with just three posts but the mounting bracket was a bit different, so I had to drill a little hole and put a sheet metal screw in.
It appears to be all fixed, at least that part. Now I just need to fix the back up alarm, and the the oil leaks and change the oil and install the black CPS when it arrives and, and....
Originally Posted by BobbyDiesel71
I have been experiencing the same issue lately, myself
off the subject: is the ORV still open in Solon? I use to wheel there with some friends from Iowa a few years ago. Camped at lake Mcbride! my father is from Independence and used to camp at Backbone as a kid
Yes the ORV park is still there. One of these days I'm going to get a 4wheeler and go play. It's a nice area to live though.
Thanks for all that posted with help. If anyone needs the part number for the solenoid I can get it for you later. It's in the wife's car and she's gone. (I love this guy).
Old Apr 18, 2010 | 07:49 PM
Beeler's Avatar
Beeler
Auto Zone Starter solenoid part number: Duralast F495.
Old Apr 19, 2010 | 01:36 PM
skinnyman94
the issue with mine was the start neurtal switch or safety neutral switch what ever u want to call it. also helps to hook up wire back up going to soleniod after u test to see if u have power from switch. a couple *******es left it unhooked and couldn't get it to start after we adjuste teh safety neutral switch
Old Apr 19, 2010 | 01:38 PM
skinnyman94
Also thanksfor the info campspringsjohn. even though u are from kentucky i wont hold it against u. WVU did kick Kentucky butt in final 4.
Old Apr 19, 2010 | 03:09 PM
CampSpringsJohn's Avatar
CampSpringsJohn
Yes they did, and we deserved it too! That's what happens if you can't shoot free-throws, and to a lesser extent, can't shoot the 3-pointer. What part of WV are you located? I do get over there on occasion. I was in Williamson, WV last week. I've been to Charleston a few times too.
Old Apr 19, 2010 | 03:33 PM
skinnyman94
i'm about an hour and a half north of charleston. on beautiful ohio river. spend a lot of time in the mountains camping though
Old May 6, 2010 | 07:45 PM
Beeler's Avatar
Beeler
Aargh, this truck is killing me. Since 4/18 it's started perfect every time. Tonight I drive home from work, stop at home to pick my daughter up for band concert, drive her to school, come out and go to start. Starter kicks in for half a second then quits. After that same problem as before, nothing when trying to start with the key. If I put the key in and turn to run, I can use a screwdriver to jump the solenoid and it fires right up. For anyone just tuning in. I tested the starter and batteries, both good. I cleaned all the battery connections, including both ends of the grounds. I replaced the starter solenoid (mounted on the passenger side fender). I have a work trip planned in one week and need it working by then. Please help!
Old May 7, 2010 | 12:51 AM
Visseroth's Avatar
Visseroth
Sounds like switch to me. Check for voltage to the pin on the solenoid that gets power from the switch that enable the solenoid to give the starter power.
If that makes any sense.
Old May 7, 2010 | 01:27 AM
Beeler's Avatar
Beeler
I will try that. I may need some guidance on exactly how to do that. I'm not very "educated" with a voltage meter, although I do own one. Would I check with the key in the run position? I'm assuming that the pin you're referring to is the smallest post, of the three, on the solenoid? Also, what do I attach the black cable from the meter to?
Old May 7, 2010 | 01:52 AM
Visseroth's Avatar
Visseroth
OK, set your volt meter to 12, 15 or 20v
On your solenoid you have 4 posts. One is hot, it's the lead from the battery, the other leads to the starter, another is negative and the other comes from your ignition switch
Have someone sit in the cab with the key in the ignition. Find your negative (ground) and positive to the switch. The two big leads are battery and starter.
Put the red on the terminal for the ignition switch and the block on your negative. Turn the key. If you see no voltage then you have either a broken or loose wire or a messed up switch.
Old May 7, 2010 | 02:02 AM
Visseroth's Avatar
Visseroth
Just found this.........
TheDieselStop.Com - www.thedieselstop.com
Old May 7, 2010 | 04:09 PM
  #28
Beeler's Avatar
Beeler
Ok, so I found the positive and negative. I put the black wire from my meter on the big negative post (solenoid) and the red (from the meter) on the small post (solenoid, the one that you just pull the wire off by hand). No reading on the meter. So I pull the small cable and and put the probe (meter) into the small wire. It reads 5 volts. Same readings are produced when the key is turned to run or start. I cannot hear the solenoid clicking except one time it was "humming", so I tried to start with the key, got nothing and the humming died. If I did the testing right it's somewhere between the key and the solenoid, right?
Old May 7, 2010 | 04:20 PM
  #29
Beeler's Avatar
Beeler
I was just reading from the link Visseroth provided in post #27. Here's one part:
Step one, open the hood and have someone turn the key to the start position. Listen for the starter relay over on the passenger side fender area near the big red battery cables; it should click when the key is turned to start. If it doesn’t, then it is not getting power. This would be a great time to see if the truck has a starter interrupter kill circuit. Some of these modules are driven by the keyless entry output from the Generic Electronic Module (GEM), and some are manual switches. It could be doing its job, or is broken.
I have a Viper remote start/security system. Is it possible that that is interrupting the signal? When I replaced the solenoid 3 weeks ago, I pulled the batteries completely out and had them tested. Maybe that reset something, although I don't know if I even have a starter interrupter kill circuit. Where would I look, or how would I find out?
Old May 8, 2010 | 12:08 AM
  #30
Visseroth's Avatar
Visseroth
Maybe someone can chime in but there are a couple places that the starter interupt is kept. One I believe to be the passenger side kick panel below the glove box, the others I don't know.
In regards to your alarm system, yes, it is possible that it is faulty. You should be seeing 12v at the small positive wire that you tested. That is the signal wire that enables the solenoid to give the starter power. If you had someone turn the key while you where checking the voltage on it and all you saw was 5v then something is a miss. You have a problem somewhere between your ignition switch and the solenoid. Next place to check would be your starter kill then check to see if you're getting the proper voltage out of the ignition switch.
Maybe someone can chime in and tell you which wire to test under the dash and where else the starter kill switch could be.
Jeff Taylor
Nov 2, 2015 10:53 AM
bcrone821
17
Jun 10, 2015 01:55 AM
Thjfarms
1997 - 2003 F150
Jun 17, 2014 12:10 AM
Kapusta
May 26, 2014 09:44 PM
pwstroker69
15
Feb 11, 2014 02:52 PM
