swappin heads
Old Apr 16, 2010 | 07:34 PM
ruskie's Avatar
ruskie
swappin heads
I have a 06 F150 with the 5.4 engine.I am curious as Ford won't honor their defective design in spark plugs. Is there an aftermarket company making and selling "HEADS" for this engine? If so -are they okay to use on stock
engines--( cams,valves,etc). And do they solve the spark plug problem?
Old Apr 16, 2010 | 07:54 PM
70f100longbed's Avatar
70f100longbed
It's not worth the hassle or expense to change the heads just for the spark plug design. It's not like you change plugs every 3000 miles.
Old Apr 16, 2010 | 09:04 PM
fordtech08's Avatar
fordtech08
you could put a lot of spark plugs in for the cost of replacing heads, besides most people will only replace the plugs once
Old Apr 17, 2010 | 01:20 AM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
in late 2007 the head design was changed
if you want to swap to the new "non-sticking" design, you will need the heads, all new cams and associated hardware. might even need new front covers and timing chains.
you are looking at an easy $3-4,000 for this sort of swap. I suggest you look at a junkyard for a low mileage 2008 motor. You are looking for one that has a build date of Nov 2007 or later. On the drivers head there is a white sticker that will have the build date.
Old Apr 17, 2010 | 08:52 AM
Ryan50hrl's Avatar
Ryan50hrl
I would suggest you just change your spark plugs to champions......they work fine and won't cost you more than 150 bucks.....
Old Apr 17, 2010 | 11:16 AM
ruskie's Avatar
ruskie
I was thinking-if you had a to pay $2500 because of broken plugs,why not put the cost towards changing the heads instead.
Old Apr 17, 2010 | 09:35 PM
Ryan50hrl's Avatar
Ryan50hrl
I don't know anyone who's getting 2500 dollar bills anymore now that the tools are out.....
capttwb
2004 - 2008 F150
Aug 21, 2013 12:44 PM
klr650goldwing
Modular V10 (6.8l)
Mar 15, 2011 11:24 PM
aceltx09
Modular V10 (6.8l)
Aug 20, 2010 10:05 AM
dacat
1983 - 2012 Ranger & B-Series
Aug 16, 2008 01:43 PM
sjrogers
Mar 2, 2007 11:44 AM
