AGSF34PP which crosses to APP5144. Make sure you don't get the ones for the ohv, as the reach is 1/4" shorter and the result will be detonation. Some stores list the same plug for both engines, this is not correct.
The stock platinum MCs had WAY too much gap erosion for me to use them again.
My thoughts also - I had gaps of .062 to .077 after only 72k miles with the factory plugs. The good news was that I had it on the dyno and it put out rated power, but the bad news was the gaps were huge. I put in autolites.
