4x4 Front Rotors
Old Apr 15, 2010 | 08:49 PM
Newenglandfordjunkie's Avatar
4x4 Front Rotors
I need to change the front rotors on my 1995 Explorer and was wandering if you need to dissasemble the hubs like on the F-150.
Old Apr 16, 2010 | 12:11 PM
zzrich's Avatar
zzrich
Yep, just did it on my '92 4x4 if there the same setup then yes.
Old Aug 12, 2013 | 11:02 PM
Razgriz2099's Avatar
Razgriz2099
They are not the same setup, a '92 is a different generation than a '95. Just remove the wheels then unbolt the caliper from it's bracket. Afterwards you should be able to pull the rotor right off. 2nd generation explorers use a hub bearing assembly. About 2 years ago I replaced the pads, calipers and rotors on my 95 explorer and soon after the wheel bearings as well. If you aren't sure of the process you can definitely find the answer using youtube.
DAPtomey
Nov 28, 2016 01:16 PM
beidle99
2009 - 2014 F150
Feb 4, 2015 11:39 AM
hood
1997 - 2003 F150
15
Sep 21, 2014 07:46 PM
Biscayne
Mar 17, 2014 10:56 AM
