Bed Mounted Spare Tire?
Old Apr 14, 2010 | 07:41 PM
Sayer Lane's Avatar
Sayer Lane
Hey guy, anybody got a bed mounted spare tire rigged up? I'm carrying mine around in the bed but its holding leaves. I took the old gas tack mount out because water and clay just stay and rust my gas tank which is something i don't need happening. So if anybody has and bed mounted spares with pics it would be much help. Thanks guys
--Sayer
Old Apr 14, 2010 | 07:50 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Here are a couple of pic's.
The first one is the mount itself, a PO moved it from the original location at the front of the bed to the rear.
The second pic is where the mount was originaly located.
Old Apr 14, 2010 | 07:54 PM
Sayer Lane's Avatar
Sayer Lane
thanks mikeo0o0o0 , now i know what they look like. Do you or anyone else whos reading this know where i could buy one
Old Apr 14, 2010 | 08:15 PM
mikeo0o0o0's Avatar
mikeo0o0o0
I took this one off and gave it to a fellow FTE member.
It wasn't a very common option, I've only seen a few of them over the years.
Maybe someone out there knows where one is.
Old Apr 14, 2010 | 08:29 PM
first today's Avatar
first today
I saw one in the junkyard in Gulfport, Miss. today. I am not sure how far it would be for you to drive there to get it though.
Old Apr 14, 2010 | 09:02 PM
Sayer Lane's Avatar
Sayer Lane
Yea from what i read it wasn't common. And the drive would be pretty long. I live in south Georgia. About 5 minutes from florida if u know back roads so it'd be a long drive
Old Apr 15, 2010 | 12:58 AM
Big_Dom's Avatar
Big_Dom
I got a half one but I use it with a rubber bungee cord. Sorry bud
Old Apr 15, 2010 | 06:11 AM
Jon Hess's Avatar
Jon Hess
I'm pretty sure you can get new ones from lmc truck. I don't know how close to original they are but they should be pretty functional.
Old Apr 15, 2010 | 10:57 AM
Witty73's Avatar
Witty73
If my memory serves me correctly, they werent actually an original ford part anyways. I think they were dealer installed.
Old Apr 15, 2010 | 03:20 PM
Furyus1's Avatar
Furyus1
The PO of my truck bolted a piece of all-thread rod to the bed rail with the other end going through one of the lug holes on the wheel.
Old Apr 15, 2010 | 05:41 PM
Sayer Lane's Avatar
Sayer Lane
Yea, lmc has em but my rims are too big, but i can weld and fabricate, so i think i'll just look around and come up with some ideas
Old Apr 15, 2010 | 06:04 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
Isn't the factory location on the Driver's side behind the cab and not the passenger side?
And I believe the Bumpsides had their bed mounted spares located in the rear of the bed, driver's side.
Josh
Old Apr 15, 2010 | 09:06 PM
Witty73's Avatar
Witty73
I am almost certain those were added at the dealer, so location was more then likely up to the customer.
Old Apr 16, 2010 | 11:46 AM
ChaseTruck754's Avatar
ChaseTruck754
If you can weld/fabricate something like this should be VERY easy to do. Just quickly thinking about it I could do it with 2 short pieces of angle iron, a tube or flat stock plate for the vertical and then a large nut/bolt and a over-sized fender type washer for the hold down.
Old Apr 16, 2010 | 11:52 AM
70 Bronco TX's Avatar
70 Bronco TX
REALLY good idea. This thread has gotten me interested in something similar, but not sure if the LMC (or even Ford part if I could find it) would work for my rims...and looking at the item, it does seem easy and customizable. And cheap Plus with the tire in place you won't really even see the bracket behind the tire, so doesn't matter much what it looks like.
