Choice: 00 SD or 97 OBS
Old Apr 18, 2010 | 08:37 AM
  #31
Brown Falcon's Avatar
Brown Falcon
Keep the OBS. A lot cheaper to upgrade the seats and stuff if your '97 than start payments on a SD.
Plus low miles on your '97, and you aren't gaining much with the 6 speed manual in the SD. You'd have a low granny gear, but the overdrive gear isn't much different.
Old Apr 18, 2010 | 07:46 PM
  #32
wildstang's Avatar
wildstang
VT Chapter Ldr
Chase if you like the SD seats better aren't they a bolt in to the obs?
Old Apr 19, 2010 | 10:40 AM
  #33
superduty4x4's Avatar
superduty4x4
I believe so, I might get there eventually.
Old Apr 19, 2010 | 01:52 PM
  #34
deadsenator's Avatar
deadsenator
Thanks guys. The OBS is staying and I am quite happy about that. I was so torn, I was figuring out how to keep both. But like y'all are saying, just adding some of the SD parts will be the path forward. I am pretty focused on the utility aspects of the truck. It has got to be a good workhorse and then provide the creature comforts. Not the other way around.
For a gear upgrade (ie - US Gear, etc) how much do those things run? I would love to have one more gear. So many times, I pull from fifth looking for sixth...
I have the split seats (in blue-gray fabric). Not a bench, but they are fairly comfortable with the flip down middle piece. I see the captain's seats and I would like to have those at some point. Where's the best place to hunt for those?
Need the SD I/C and pipe kit, too. Have a SD van turbo sitting on the coffee table waiting for a rebuild kit and the other parts to add it in (Clay and I will work this part out, I am sure.)
I will post another thread on the topic, but someone is offering me a TS 6-pos for $175. It's off a 02, so it'll need a reprogram ($50). Is $225 worth it? I know I need injectors to make it all work right, but I was just looking for an interim electronic upgrade (currently run a Superchips tuner). No need to crank out black smoke, but towing power and economy are the goals. I know I could but a TW or something else for $400+, but I was just trying to save a little dough.
And how do you get to the ECU to plug this in? Under the dash or under the hood?
Old Apr 19, 2010 | 05:17 PM
  #35
Brown Falcon
Check out a PHP chip from Jim. DIY-Injectors.com
Got mine for a good price, less than TW or DP Tuner.
To get to the ECU in our trucks you have to pull it out through the engine compartment...
97PowerJokeNeverWins
18
Nov 30, 2014 12:38 PM
disco biscuit
Oct 4, 2013 08:51 PM
DIYMechanic
17
May 25, 2011 04:09 PM
reckinbar
Oct 4, 2010 12:17 PM
