Weird really HELP!
Old Apr 13, 2010 | 08:36 PM
northerndave's Avatar
northerndave
Originally Posted by vol1966
Well i replaced that power valve and it still does it
dude you're funny.
And hey, I just flew to the moon and it really is made of cheese.
huh...
weird.
(that was a little fast dude, just sayin)
Old Apr 13, 2010 | 08:49 PM
vol1966's Avatar
vol1966
I really did.... got a bud that works at Advance just 2 miles down the road he dropped it off to me
Old Apr 13, 2010 | 09:14 PM
northerndave
Well ya undid the throttle linkage, kickdown linkage, springs, fuel line, egr line, vacuum lines, unscrewed the heat riser tube fitting for the thermo choke, the 4 base nuts for the carb, pulled the carb, flipped it over, spun out the 4 power valve cap screws (was there gas in there?) unscrewed the old P-valve, spun the new one in, re atached the P-valve cover & screws, bolted the carb back on the truck, hooked all the stuff back up... cranked & cranked & cranked on the starter to refill the float bowl, and then it fired & did the same thing?
I maybe coulda done that back in the day when I could crawl around under the hood of a truck with my knees on the radiator & one hand resting on a valve cover holding myself up. But in the 37 minutes between your posts... Well...
Maybe if I had all the tools right there ready to go.... naw, I just aint that fast anymore.
:grin:
Old Apr 13, 2010 | 09:21 PM
vol1966's Avatar
vol1966
well it has no kickdown
as far as vacuum lines it has none to the carb
all i had to unhook was the 4 bolts, throttle linkage and brass tube to the choke
Old Apr 13, 2010 | 09:29 PM
vol1966's Avatar
vol1966
Old Apr 13, 2010 | 09:30 PM
vol1966's Avatar
vol1966
Old Apr 13, 2010 | 09:40 PM
vol1966's Avatar
vol1966
Oh and for your info it was over an hour hour..I called my bud and told him to drop it off ..he did 10 mins later while i was unhooking the carb .. 4 bolts took abour 1 min each to take off for a total of 4 mins
throttle linkage took about 1 min to take off the clip and unhook the spring
pull carb and flip over and take 4 small bolts out maybe took 10 mins at most
so YES i had time
Today, 08:08 PM ...your first post saying it may be the p valve
Today, 09:24 PM ...my post saying i replaced it
Old Apr 13, 2010 | 09:43 PM
northerndave
no choke pull off... hmm.
and I can see what looks like the supply line port for the whole thermo-choke vacuum ciruit but there is no line to it.
in this picture
which I guess is probably not such a big deal (function wise) because it's just to filter that air flow.
but the choke pull off... is there a vacuum port on the rear passenger side of the carb base?
That's where the vac port for the choke pull off would be if there was one.
Old Apr 13, 2010 | 09:44 PM
northerndave
so YES i had time
so did any gas spill out when you took the p-valve cover off?
any gas inside there?
Old Apr 13, 2010 | 09:47 PM
vol1966's Avatar
vol1966
choke pull off
u talking about the brass line that runs from the exhaust manifold to the carb?
Old Apr 13, 2010 | 09:51 PM
vol1966's Avatar
vol1966
Got a good pic of the back
Old Apr 13, 2010 | 09:55 PM
northerndave
no, if it had one it would be on the rear passenger side of the carb. A vacuum diaphram with a pull rod that reaches forward to the choke linkage.
It maybe never had one, I don't know. But if it did then there may be an uncapped vacuum port at the rear passenger side of the carb base.
that would be a pretty nasty vac leak.
man, i got the *** hat on, this is a little different setup than i pictured.
you do have a kickdown but it's all divorced from the carb itself.
Old Apr 13, 2010 | 09:57 PM
  #28
northerndave
good pic, nuthin there tho.
definately not a choke pull off carb.
must be too old for that junk.
Old Apr 13, 2010 | 09:58 PM
  #29
northerndave
where does that rubber vac line go to that runs just under your brass choke tube fitting?
Old Apr 13, 2010 | 10:01 PM
  #30
vol1966's Avatar
vol1966
Like I said the only vacuum lines are the big one below the carb u can see it in the pic...it runs to the PVC in the oil cap
to answer your ?
and the smaller hose in that pic..runs to the distributor from the tree in back of the intake
it runs and idles good in D when i unhook that line...also when its hooked up it makes a loud clicking clacking sound at the distributor and does not when unhooked
