It now appears that the cup on the frame that holds the pin on the glass frame. (for lack of a better way to phrase it) is also broken. It the frame that mounts in the door also the same?
Sorry, I do not understand what you are describing.
The vent frames are right/left specific, as are the retainers that the vent w/strips attach to.
These parts have the same applications as the glass.
These trucks vent frames are different L to R...glass, as Bill said is the same...I have a good glass in a bad frame if its needed...cheap too...if you need the frame assembly itself(the black portion with the splined shaft) Let me know which side you are in need of......plus Im close to ya also...relatively...
if you are in need of other door stuff, inquire within.
