Side Glass Thickness
Old Mar 4, 2015 | 11:51 AM
ryanf77's Avatar
ryanf77
I ordered new Wing Window and Side Window Glass from LMC Truck for My Son's 67 F100... In the process of Installing it We realized that the new Glass does not fit the Wing Window Frame. I looked at the Old versus the Ne and notices the thickness was different. I measured the old at .194" and the new at .231" - well over 1/32" difference... Anyone else run into this problem? If I can get the Wing Window Glass to Work will the Side Windows still roll up and down? We replaced the Window Rubber/Felt already and so it is already tight rolling up n down... Thinking We may need to just go have Custom Glass Made or try cleaning up the old stuff to look good again... Suggestions???
Old Mar 4, 2015 | 05:00 PM
JEFFFAFA's Avatar
JEFFFAFA
Contact LMC. I don't remember width choices on Bumpsides.
Old Mar 4, 2015 | 05:57 PM
ryanf77's Avatar
ryanf77
Originally Posted by JEFFFAFA
Contact LMC. I don't remember width choices I Bumpsides.
I contacted them... Here is their response:
Hello Ryan,
Thank you for your email. We have checked our stock. All of our stock for part 49-4320 vent glass, measures .231” thick. You may return the part if you wish by following the instructions on the back of your invoice.
Best regards,
Bethany M
Customer Care
Long Motor Corporation
P: 1-800-562-8782
F: 1-800-541-8525
Old Mar 4, 2015 | 10:43 PM
orich's Avatar
orich
Just return it all and check with other vendors, LMC is known for having cheaper prices.
And most everyone finds out you get what you paid for with LMC.
It seems most all their rubber products fail with in a few yrs. From the UV or ozone drying them out and causing it to crack, made as cheaply as they can. LMC.
I and many other have found out the hard way after buying and installing their products
Not many items, I'd buy from them any more.
My 02cents
Orich
Old Mar 5, 2015 | 10:09 AM
ryanf77's Avatar
ryanf77
My 02cents
Orich
Oh GREAT! I already got some seals from them and installed them!!! Do You have any other Companies that You suggest? I've got a couple items from Dennis Carpenter and from Tom's Broncos but if You know of good other suppliers I'd love to know of 'em too...
Old Mar 5, 2015 | 02:25 PM
JEFFFAFA's Avatar
JEFFFAFA
I check DC 1st. From there I suggest checking out HioSilver's compilation sticky top of our Home Page. (says "read first")
4 rings
17
Dec 17, 2018 12:29 AM
Leovardo
Jul 23, 2017 02:18 PM
mgargiullo
Mar 29, 2014 04:07 AM
codyjoe
Missouri Chapter
50
Oct 4, 2009 10:42 PM
Sparksone42
Dec 16, 2006 10:37 AM
